lemme guess. wheel bearing is needs to be replaced?
Old Dec 17, 2009 | 11:24 PM
accordfreak's Avatar
accordfreak
Default lemme guess. wheel bearing is needs to be replaced?
the wheel is on tight at 80lbs of tq yet the wheel can move back and forth. It doesn't move side to side though.. crappy nissan wheel bearing?
EDIT: the culprit: I found out the axel nut is loose. It was so loose i was able to loosen it by hand with no tools. so whoever has the axel clicking noise should not ignore it.
<object width="400" height="300"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=8252168&amp;server=vimeo.com&amp;show_ title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp ;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=8252168&amp;server=vimeo.com&amp;show_ title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp ;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="300"></embed></object><p><a href="http://vimeo.com/8252168">quality nissan wheel bearing driver side rear 50k miles</a> from <a href="http://vimeo.com/user2606635">accordfreak</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
Old Dec 18, 2009 | 01:35 AM
boosted99gst's Avatar
boosted99gst
you sir are correct!!
The bearing is located in the hub assembly which is a non serviceable part..unfortunately you are going to have to buy the entire assembly for the fix.
Old Dec 18, 2009 | 02:53 AM
terrasmak's Avatar
couldn't tell by your vid, but make sure its not a suspension bushing giving the play
Old Dec 18, 2009 | 10:37 AM
accordfreak
the brake rotor moves with the wheel while nothing else moves. so i guess it is wheel bearing. thanks for the response. ugh this sucks.
Old Dec 19, 2009 | 01:04 AM
accordfreak
Old Dec 31, 2009 | 12:54 PM
accordfreak
aparently honda engineers are smarter than nissan engineers.
s2k's also have a click issue also but they resolve by staking the nut preventing it from being loose
look at the pic below. the nut is dented in.
Axle Pops or Creaks:
'00–02 S2000
On '00–02 S2000s, if your customer complains of hearing a single pop or creak from the rear of the vehicle when changing direction from forward to backward and vice versa, the problem may be axle (driveshaft) movement in the rear hub. To eliminate the noise, replace the spindle nut on the affected axle. Apply grease to the surface of the new spindle nut where it contacts the hub. Torque the new nut to 298 N·m (220 lb-ft), and stake the nut.
so with our crappy nissans, it's going to happen every 20k miles. go nissan..
Old Jan 4, 2010 | 03:50 AM
KillerRide350Z's Avatar
KillerRide350Z
Hmm, thanks for the information. You actually helped me out because I am having the same noise. I am going to check it out tomorrow. I was wondering what the heck that noise was haha.
Old Jan 4, 2010 | 04:06 AM
JasonZ-YA's Avatar
JasonZ-YA
'00–02 S2000
every 20K is a pretty great exaggeration..........i myself along with many others have yet to experience this.....I drift and autoX and im aware and check for it yet nothing thus far.....
what your talking about with the honda's is the axle actually clicking/moving in the hub, so the nut needs to be pinched to retain the axle in....with the Z the bearings are actually going out and need replacing, seemingly two different issues altogether...as the z is known to have bearing replacement up front as well......no axles there buddy....
-J
Old Jan 4, 2010 | 04:58 AM
zerafian's Avatar
zerafian
your the first person EVER, that Iv seen, to have problems with nissan wheel barings LOL...Im 60k miles in and no problems.
Old Jan 4, 2010 | 05:01 AM
JasonZ-YA's Avatar
JasonZ-YA
Im at 85K...
-J
Old Jan 4, 2010 | 07:45 PM
zerafian's Avatar
zerafian
OP your such an exaggerator.
Old Jan 4, 2010 | 08:19 PM
hndumafia's Avatar
hndumafia
It is not that uncommon to wear out the front wheel bearings on the Z. It happened to me around 45k miles or so. I attribute the early wear to lots of auto-x runs and laps around the gainesville road course, and suspect that under normal street driving it would have not had a problem so early. It seems like kind of a crap-shoot though, seeing as someone like JasonZ-ya hasn't had this issue yet, and probably does more hard driving than I do.
OP, if you look through the tech DIY section you can find the thread I posted with diy for the wheel bearing. It's super easy to replace.
Old Feb 8, 2010 | 09:13 PM
G35-31's Avatar
G35-31
bont it have a cotter pin in it though how could it unloosen?
Old Feb 8, 2010 | 10:30 PM
accordfreak
the cotter pin is still approx 5mm away from the axle nut. It doesn't prevent the nut from turning, it just prevents the nut from backing up all the way.
Old Feb 12, 2010 | 10:03 PM
G35-31's Avatar
G35-31
wow, i just checked mine today i kept hearing a loud thud noise , the nut was loose enough to where i can use my hand to take it off, crazy!! but now nomore thuddd noise!!!
Old Mar 7, 2010 | 12:42 PM
cloom350z's Avatar
cloom350z
Have U checked knuckle ?? maybe that thing was loose what kind of susp r u running ?? from my experience if your hub bearing is going u can shift wheel up and down also side to side. i think u should check your bolts in the back of the knucle
Old Mar 10, 2010 | 06:34 AM
ashtrojan2008's Avatar
ashtrojan2008
replaced my driver rear bearing yesterday.. $95 from Nissan. I took pictures, maybe I should do a write up.
Old Mar 10, 2010 | 07:02 AM
Unique_Z33's Avatar
Unique_Z33
ashtrojan, please do. OP, wtf that's scary! Hope you get it fixed.
Old Mar 14, 2010 | 01:20 PM
ceevee's Avatar
ceevee
I'm experiencing the exact same thing on my 2003 350Z with ~62,000 miles, driver's side rear. My mechanic said that I needed a new wheel bearing, so I got a new wheel bearing installed at his shop last week.
Today, I was getting my tires done and the tech told me that the left rear wheel has a lot of play. Back and forth, just like you.
Since I just got that wheel bearing done like a week ago, I'm not sure what's going on. Gonna get it looked at by the guy who did mine again.
Old Dec 14, 2010 | 09:21 PM
KingBaby's Avatar
KingBaby
Hardest Setting
saved!
