Need help with spacer size. Got 9.5/10.5" wheels with diff offsets
So this is what I've got:
2005 a/t Touring Z that came with stock 17's. I replaced the 17's with 18 inch Enkie RPF1 wheels.
The front wheels are 18x9.5 with a 40mm offset and 245/40/18 tires.
The rear wheels are 18x10.5 with a 15mm offset and 275/40/18 tires.
I love the way the back looks as it sits flush with the fender for a very aggressive look. However, the front wheels sit inside the fender slightly and I want them to sit flush with the fender. I'm confused as to which size spacer I will need for the front? Also, I'de like to get spacers that come with long enough studs
20 or 25mm would work well
http://www.z1auto.com/prodmore.asp?m...ls&prodid=3625
we have both in stock if you need them
my car is at stock height. I just want the wheels to be flush with the fender. I guess what Im asking is what would be needed to make that happen? I don't want the front sticking out further then the rears.
15mm, 20mm, 25mm....
I don't need spacers on the back
You have the car to check - I do not. I would measure the distance between the tire and inside fender. See how much room I have for spacers.
5mm for rear 25mm for the front..and drop to 35 profile tires
AFter reading your latest post further describing what your looking for Go with 20mm on the front and thats it
