quick offset ?
Old Jan 6, 2010 | 07:36 AM
duro78's Avatar
duro78
Default quick offset ?
Just ordered new wheels and wanted to have an aggressive stance. Decided on a square setup so the wheels are 18 9.5 +15 all around. im currently running a 25mm spacer in the rear and 15mm in the front. I wanted a mild stretch to accomodate the stance so what tire sizes should I run? will I be able to run my spacers for a more aggressive stance or suggest new spacer sizes. I will run slightly wider tires in the rear. Im not opposed to rolling fenders.... I searched for similar setups but came up with nothing. oh yeah im dumped on gf210's. Please help im about to order tires. Thanks
Old Jan 6, 2010 | 08:09 AM
scotts300's Avatar
scotts300
Post your question over here: https://my350z.com/forum/wheels-and-...s-welcome.html
Old Jan 6, 2010 | 08:28 AM
terrasmak's Avatar
245/40 front and 245/45 rear? Maybe
Old Jan 6, 2010 | 03:26 PM
Never mind. I thought this was important to you. Important enough to say “thanks” or simply reply.
Old Jan 6, 2010 | 03:59 PM
maxevo's Avatar
maxevo
245/40/18 will give you a mild strech
235/40/18 will give you a little more aggressive stretch
Old Jan 10, 2010 | 05:34 AM
KillerRide350Z's Avatar
KillerRide350Z
I would go with 245 in front.
Old Jan 10, 2010 | 05:36 AM
04fairlazdyz's Avatar
04fairlazdyz
LOW N SLO
You have no need to stretch tires on that set up. People only stretch tires so they don't rub the fenders. Your wheels are'nt wide enough for that
Old Jan 10, 2010 | 11:03 PM
shake_urzada's Avatar
shake_urzada
http://www.rimtuck.com/thumbnails.ph...clemodel=350Z&
check out this gallery of different fitments to help you decide.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
