Need crazy offsets
Old Jan 11, 2010 | 05:48 AM
meatbag's Avatar
meatbag
Default Need crazy offsets
Looking for one piece forged wheels that are 19x10 -38 and +38 offsets. Anyone know of a company that does wheels in these sizes?
Old Jan 11, 2010 | 09:32 AM
CORNELL's Avatar
CORNELL
those aren't crazy you could find a lot of wheels with those offsets. try staying lower than +20
Old Jan 11, 2010 | 12:08 PM
meatbag's Avatar
meatbag
The +38 im not to worried about, I havent been able to find one in -38
Old Jan 11, 2010 | 05:40 PM
rodneeking85's Avatar
rodneeking85
You'll have to probably do a special order. In one piece though i'm not sure you'd even be able to get an offset that low. It's usually 2 piece wheels or 3 piece where you can get deeper in the negative range, I may be wrong though.
Old Jan 11, 2010 | 06:40 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I don't think you're going to find anything even remotely close to the -38 in a 2 piece wheel
Old Jan 11, 2010 | 08:07 PM
A drag racing wheel will suit your offset needs but not diameter. I know of no 19 inch drag racing wheels. Several companies may build wheels to your specs: http://www.streetdreams.org/custom-built-wheels.php
Old Jan 11, 2010 | 09:19 PM
meatbag's Avatar
meatbag
My car is widebody, was trying to do a wheel with no lip but it might not happen
Old Jan 12, 2010 | 02:16 AM
maXmood's Avatar
maXmood
Under Boost!
with -38, you mean a lip you can sleep on..
Old Jan 12, 2010 | 05:36 AM
meatbag's Avatar
meatbag
Already have a set of wheel for showing with that have a huge lip. Looking for something different that gives me more tires choices and can put up with track days.
Old Jan 12, 2010 | 06:23 AM
terrasmak's Avatar
18x10.5 +15 rpf1's with a 25mm spacer should probably work fine for trackdays.
Old Jan 13, 2010 | 05:40 AM
maXmood's Avatar
maXmood
Under Boost!
tho, are spacers a good idea for trackdays?
Old Jan 13, 2010 | 07:41 AM
terrasmak's Avatar
As long as you get high quality spacers they are just as good as any neg offset wheel.
Old Jan 13, 2010 | 09:02 AM
fatboy.yoshi's Avatar
fatboy.yoshi
good luck trying to find 19x10 -38... 19x10 -38 will sit about the same as 19x11 -26 or 19x12 -14 give or take a few mm
seagrasser
Oct 11, 2015 03:27 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
