Enkei rpf1 fitment
Old Jan 23, 2010 | 04:01 PM
Jopper77's Avatar
Jopper77
Default Enkei rpf1 fitment
looking at getting a set of Enkei RPF1 9.5/18 and 10.5/18 with a +15 offset all around. With 275/40 tires on the back, lowered one inch, do you think I'll be rubbing?
Old Jan 23, 2010 | 05:14 PM
It will fit just fine.
Old Jan 23, 2010 | 05:32 PM
BiggieB15's Avatar
BiggieB15
go with 19"...
Old Jan 23, 2010 | 05:33 PM
03threefiftyz's Avatar
03threefiftyz
Originally Posted by BiggieB15
go with 19"...
Why?
Old Jan 23, 2010 | 08:07 PM
Jopper77's Avatar
Jopper77
I found a place that has RPF1's in black and gunmetal. My 350z is silver and wonder how the gunmetal would look. Also considering the SBC - bit more cash but they do look nice.
Old Jan 24, 2010 | 12:04 AM
terrasmak's Avatar
Yes you will rub, my car started rubbing at +25 with a 275/40 INVO on a 10.5 and -2.0 camber. A simple roll with take care of it, or buy Falken 452's, they are narrow as hell.
Old Jan 24, 2010 | 01:51 AM
drivessidewayz's Avatar
drivessidewayz
INVOs are wide as hell too. To match the stock Bridgestones on the rear you probably need like 225/45 >.<
Long story short: it depends on the tires.
Old Jan 24, 2010 | 05:53 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
https://my350z.com/forum/wheels-and-...i-rpf1s-2.html
Old Jan 24, 2010 | 02:15 PM
Jarrod's Avatar
Jarrod
great choice! I have rpf1(18) 10.5 on the rear with 295's. I am lowered 1.2 in the rear and I have no rubbing. I did get a rear camber though,hope this helps.
Old Jan 24, 2010 | 02:25 PM
Jopper77's Avatar
Jopper77
Thanks Jarrod - It does and I'm collecting as much info before I move forward. It's really between the RPF1's or GTCO1's 9/18 +18 front and 19/18 +22 back. I know this isn't as agressive but should look pretty good.
Old Jan 24, 2010 | 07:14 PM
kennedy's Avatar
kennedy
Hey I have the same set up but with wider tires I am letting go so if you dont have tire let me know but you will have to roll your rear fenders.
Old Jan 24, 2010 | 07:34 PM
Jarrod's Avatar
Jarrod
Sorry I didn't mention that to be smart I did have my rear fenders rolled ( $50 per fender).
Old Jan 24, 2010 | 07:40 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Do you have the Brembo brake option? If so, you'll need to run spacers up front to gain adequate caliper clearence.
Old Jan 24, 2010 | 08:19 PM
kennedy's Avatar
kennedy
B/s I have wilwoods on the front of my car which are bigger then brembo's and I have no issues with clearance
Old Jan 24, 2010 | 10:22 PM
03threefiftyz
I'd think with +15 offset he should be fine for caliper clearance.
Old Jan 25, 2010 | 06:24 AM
scotts300's Avatar
scotts300
Which size Enkei RPF1 wheel do you have?
Old Jan 25, 2010 | 07:00 AM
ZRated67's Avatar
ZRated67
I'm running Enkei RPF1's 17X8.5 +30 up front with no issues regarding my Brembos.
Old Jan 25, 2010 | 07:50 AM
scotts300's Avatar
scotts300
If you had the 17x9.5 wheel there would be a problem with the Brembos, which is likely why Dkmura made that comment.
Old Jan 25, 2010 | 07:57 AM
EL Matador's Avatar
EL Matador
Hey Jarrod you have pics of this setup?? And what brand tire are you running?
Old Jan 25, 2010 | 12:34 PM
kennedy's Avatar
kennedy
+15 on all 4 wheels 18x9.5 and 18x10.5
