Spacers needed? Wheel & tires ordered
point taken but little confused...
calculating the size to inches for the tires I get
275 = 10.83 inches
last time I checked
10.83" > 10"
Yes/No?
245 = 9.66 inch width
less than 1/2 inch below the 10" of the wheel
reason I am assuming this would produce just a slight stretch
255 = 10.04 inches
pretty much bang on
regards to the front
225 = 8.86 inches
less than 1/4 inch below the 9" front wheels
I am just str8 converting from mm to inch
guess it might work out differently when it actually comes down to the actual wheels & tires.
I have no experience with this so forgive the lack of understanding in real terms - if there is a difference.
275 = 10.83 inches
last time I checked
10.83" > 10"
Yes/No?
255 = 10.04 inches
pretty much bang on
225 = 8.86 inches
gotten mm widths allover the board from smaller in front vs wider in rear to even wider spacer up front vs smaller in rear.
and some advice from 15mm up to 25mm on fronts and vice versa in the rears.
So yeah - will more than likely test fit measure and then buy spacers.
- didn't realize till now that the title might confuse whether or not I "need" spacers.
DarkCreep
Oct 17, 2015 11:50 PM
