Putting on Volf SF Winnings ... please help ...
Old Oct 24, 2003 | 10:29 AM
350trackz's Avatar
350trackz
Default Putting on 19" Volk SF Winnings ... please help ...
Wanting to put 19" SF Winnings on my SB Track. What is the MAX offset I can get get a deep lip AND clear the calipers ? Also, what color do you guys tink ? Gunmetal, silver, or mercury silver.
PLEASE post pics if you have them.
Old Oct 24, 2003 | 10:51 AM
john350Z's Avatar
john350Z
max size and offset:
front 19x9.5 19mm offset with 245/35 19"
rears 19x10.5 17mm offset with 275/35 19"
rear fenders will need to be rolled, especially if you drop the car.
this is what i have.
smaller size is:
front 19x8.5 25mm offset with 245/35 19"
rears 19x9.5 29mm offset with 275/35 19"
these sizes and offsets are from volk racing japan themselves.
Attached Thumbnails Putting on Volf SF Winnings ... please help ...-nismo-cf-body-kit-019.jpg
Old Oct 24, 2003 | 01:50 PM
jran76's Avatar
jran76
Hey John
Will the 25mm offset on the 8.5" front clear the Stoptech's?
Old Oct 24, 2003 | 01:54 PM
john350Z's Avatar
john350Z
Originally posted by jran76
Hey John
yes, it should
Old May 12, 2005 | 09:15 PM
Cyp's Avatar
Cyp
[QUOTE=john350Z]max size and offset:
smaller size is:
Are these the only two 19 inch wheel combinations for the 350z? Is the "smaller size" combination the biggest lip you can get without rubbing after lowering the car?
Old May 13, 2005 | 09:01 AM
LATEZ's Avatar
LATEZ
can roll 19x10 with +25 offset for the rear without rollin the fender
Old May 13, 2005 | 11:16 AM
bwzabodyn's Avatar
bwzabodyn
I have SF_winnings in a little different offsets...
9.5 +29 (same size lip as +19, will not clear Stoptech's though)
10.5 +29 rear (no fender rolling required)
I recommend the 9.5 +19, 10.5 +29 combination as it's the best of both worlds - clears BBK in the front and NO fender mods required in the rear...
here's some pics of my setup...
Old May 13, 2005 | 02:18 PM
Road Warrior's Avatar
Road Warrior
nice ride!
are you lowered?
Old May 13, 2005 | 02:56 PM
Zquicksilver's Avatar
Zquicksilver
Your going to love the SF's
my setup:
8.5 x 19 @ +25
10.5 x 19 @ +29
245/295/35 19
stock height, base brakes, no rolling or rubbing...
i'm lowering it soon though on RS*R springs (0.5") F/R. i will have to roll after that due to the fact that i have large tires and the fender will be sitting right on the tire visually. Looking forward the M3 look...ie fill the gap by either lowering a lot $$$ or getting 35 + series tires on 19" rims.
the guys i've see with:
9.5 x 19 @ +19
10.5 x 19 @ +17
usually run 30 series tires, lower the car an 1" or more (usually requires camber kits) and they roll the fenders...
all of that was not worth it to me, so i went with what i did
good luck,
Zquicksilver
Old May 14, 2005 | 11:03 PM
2 low Z's Avatar
2 low Z
I know I'ver asked this already, but I've only came up with pics of G35s with this set up and one red Z. But because of the pics of the red Z, and his tire selection it's hard to tell just how they fit.
Has anyone had any problems with the +19F, +17R setup? Do they stick out past the fender ANY when the rear camber is corrected to stock after lowerering? I'd rather not roll my fenders, but it's no big deal if I have too. I just don't want the tires to be sticking out past the fender.
I've been waiting about 2 months for my +19F, +29R to come in. They should get here in about 2 weeks, but the longer I wait, the more I second guess my decision.
Old May 14, 2005 | 11:08 PM
2 low Z's Avatar
2 low Z
bwzabodyn,
Do you have any pics of the +19F, +29R setup. I've been searhing and searching but no luck. I know the lips sizes are the same as your setup, is the lip noticeably different between the front and back?
And BTW, I have to tell you again how sweet you G looks.
Old May 15, 2005 | 03:23 PM
bwzabodyn's Avatar
bwzabodyn
1) yes I am lowered on Hotchkis springs - around 1" all the way around - a little more in the rear than the front
2) if you go to g35driver.com and search you'll find a pic of the setup (a diamond graphite coupe with merc silver winnings) - if you have Brembos or a bbk, the 9.5 +19 is the way to go in the front
3) lip is 2.75" in the front and 3.35" in the rear - plenty noticable difference for me and I love the big lip in the front...
good luck and thanks for the compliments!
Old May 26, 2005 | 08:04 PM
plastiketa's Avatar
plastiketa
With 19x9.5 in the front, do you still have the full turning radius?
Old May 27, 2005 | 06:46 AM
NA&CH's Avatar
NA&CH
I am not sure on the offset and size. But what about some Gold rims on the SB???
Old May 27, 2005 | 08:45 AM
Road Warrior
that would look alright but i think gunmetal or hyperblack would look sick on an sb...thats what i have and i am trying to decide on color too
Old Jun 11, 2005 | 07:36 PM
1G-350Z's Avatar
1G-350Z
I have the Mercury Silver on SB... 19x9.5(19) 19x10.5(17) and the car looks super clean... The aggressive offset, and dropping it is key. Filling out the wheel well changes the look of the car... I need a good rear camber/toe kit... I'm looking into that now
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Tochigi_236
Sep 27, 2015 03:40 PM
