245 or 255/40/18 for lowered nismo....need some input
Old Feb 21, 2010 | 08:59 AM
nismo542's Avatar
nismo542
Default 245 or 255/40/18 for lowered nismo....need some input
i am about to pull the trigger on getting some new tires. i am kinda pissed that the re050a only lasted 15k miles. i am going with the hankook ventus v12 evo k110.
i am lowered on stance gr+ about 1.25" basically no wheel gap. i am going with 275/35/19 in the rear and i will address the fender rolling if needed and adjust ride height as necessary, so i am not too concerned about that.
my concern is the fronts. i am looking at 245 or 255/40/18.
-should i stick with the 245 up front or should i increase the fronts because i increased the rear tire size?
-if i did 245/275, would 30mm difference in front and rear cause any issues?
i have read a lot of threads about this on stock height, but i would like some input from anybody that has run these sizes on lowered Zs.
thanks
Old Feb 21, 2010 | 09:46 AM
Thumbs up
Difference in overall tire height is 13.9 mm. This is good.
Old Feb 21, 2010 | 11:05 AM
nismo542's Avatar
nismo542
thanks, I looked at that calculator too. I figure either size would be fine as far as tcs. my main issue was handleing and rubbing. anybody with personal experience?
Old Feb 21, 2010 | 01:06 PM
Spike100's Avatar
Spike100
thanks
The tire size you are considering for the rear (275/35-18) has an overall diameter (height) of 25.57”.
If you go with a 35 profile on the 275 rears, you must not mount a 40 profile (245/40-18 or 255/40-18) on the fronts. (You said: “my concern is the fronts. i am looking at 245 or 255/40/18.”)
A 40 profile with a 245 or 255 wide tire has a greater overall diameter than the 275/35-18’s you are considering. A taller tire in front messes up the electronic functions (ABS, and VDC/TCS if your car has this).
If you go with 275/35-18” rears, you should go with a 35 profile on the front. Either 245 or 255 widths will work fine. If you prefer reduced under-steer and don’t mind heavier steering, go with 255/35-18”. Otherwise, go with 245/35-18” for your setup.
Since your car is dropped, a 35 profile should look OK.
--Spike
Old Feb 21, 2010 | 02:46 PM
nismo542's Avatar
nismo542
the rears are 19" not 18". 275/35/19 would actually be slightly taller than the 265/35/19 that are stock.
that is why I am wondering if I need to go with the 255 up front so that the overall height difference would stay the same as stock but front and back tires would be wider.
I know this setup will work fine on stock height, but just wondering about front clearence with the 255/40/18 when lowered.
Old Feb 21, 2010 | 05:54 PM
Spike100's Avatar
Spike100
^^ Oops... never mind...
Old Feb 22, 2010 | 01:46 PM
nismo542's Avatar
nismo542
anybody have a 255/40/18 +30 offset on a lowered z?
May 30, 2017 03:28 PM
