Tire size question
Old Mar 15, 2010 | 04:54 PM
Spike100's Avatar
Spike100
Originally Posted by Zenica
Hmmm, it has been a while since I took a wheel off to get to the fenderliner
but I'd swear I didn't have such a bolt...I will look to be sure my memory isn't getting faulty!
Do you think a rear rim with 235's mounted up front would cause any rubbing issues without a spacer?
You will not have any issues with rubbing on the front with 235’s. As Scott states, he’s running 255’s on the front.
Think about these points:
  • The front wheels turn. That means that even a relatively “thin” tire (such as a 225 width) must clear the front fender in a lock-to-lock turn since the tire height must clear your front fenders.
  • And, that also means that the front fender will accommodate a very wide tire (some members here go as wide as 275mm on the front).
  • You don’t need to roll front fenders to accommodate “wide” tires (again, the front wheels turn outside the front fender).
  • For your front tire, you only need to consider overall tire diameter, and not tire width.
Let me just offer one additional comment: I run all-square with my winter wheel/tire setup. For this setup, I use the same wheel diameter/width and the same tire size front and rear.
Here is my recommendation based upon the information you provide on your thread:
  • Buy a second set of stock wheels (or at least the rears if you can get these by them alone). If you are going all-square, the best way to do this is with 4 wheels that are the same size (height, width, and offset).
  • Mount the same size tires on all four corners. If you go 235’s on 17” wheels, mount 235/50-17” all around. If you go with 225’s on 17” wheels, go with 225/55-17” all around.
I should also mention that a 17” wheel allows a greater selection of tire-width on various wheel-widths than you have with 18” or 19” wheels. That is simply because the section height is greater on a 17” wheel, and more forgiving when fitting tire widths than you have with taller wheels.
Hope this isn’t confusing,
Spike
________________
PS: Please post back to this thread telling us what you decide to do and how you evaluate the results. That helps us learn.
Old Mar 15, 2010 | 08:20 PM
Zenica's Avatar
Zenica
Spike
________________
Very informative, thank you.
I am 99% sure I will go with 4 stock Nissan "rear" wheel rims all around
mated to 235/50/17 tires.
I will post a few pics once it is done but I expect it to look the same as it does now.
Thanks again...very informative.
Old Mar 20, 2010 | 08:04 PM
Zenica's Avatar
Zenica
Picked up a set of stock 17" wheels and tires from fellow board member DavidV
for a smokin' deal (Thanks David!) I will mount them next week and report back...
And a 2nd thanks to David, he cleaned them puppies up so nice, they looked brandy new!
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
Paul.
Oct 16, 2015 07:34 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
