305's
Old Mar 16, 2010 | 01:42 PM
scotts300's Avatar
scotts300
Originally Posted by Bumpinjeep
My car is fairly low, ok its pretty damn low and i'm running 305x30x19s in the back, the camber is between -2 and -3. Tractionwise its great. I would recommend it. I suppose the looks are subjective but I think it looks more like a race car. I honestly dont see that much neg. camber on TimeAttkz's car anyway. Its important to choose the right wheel too. You dont want a heavy *** wheel with huge tires.
What size wheel and what offset? You got new ones since yours were stolen?
Old Mar 16, 2010 | 03:53 PM
Bumpinjeep's Avatar
Bumpinjeep
Got replacement set shipped over. 19x9.5 +22 and 19x10.5 + 22 CE TAs.
Old Mar 17, 2010 | 06:58 AM
idrive_MD's Avatar
idrive_MD
I like my 295/30's but I think I might try a 305/30 setup next time around.
Old Mar 17, 2010 | 09:09 AM
scotts300's Avatar
scotts300
19x11 +33? 305/30 should be ok.
Old Mar 21, 2010 | 01:22 AM
idrive_MD's Avatar
idrive_MD
rears are easy, finding fronts without being too small is tough. Right now at 255/35 and 295/30 I'm at 26" tire height front and rear with a slight bigger stretch in the front so I imagine its a smidgen smaller (similar to stock). I would like to get a 265 or a 275 up front, but I just dont think it will work and or fit...I dunno, I'll worry about it when the time comes.
Old Mar 21, 2010 | 04:11 PM
scotts300's Avatar
scotts300
275/30 should fit and be ok on your front wheels.
Old Mar 22, 2010 | 05:20 PM
idrive_MD's Avatar
idrive_MD
you think I should keep the front/rear stretch similar and go with 275/30 front and stay 295/30 rear or move up to a more square sidewall setup in the rear with the 305/30?
I'm not in need of the extra grip because I am mostly stock, performance wise and dont ever plan on going FI, but I do enjoy a grippy car.
Old Mar 23, 2010 | 07:45 AM
scotts300's Avatar
scotts300
Yeah, 275/30 front and 305/30 rear should work. I'd try to borrow a set of 305s or buy a cheap used set that you could resell if you had to. Your high offsets should be ok, but it may be close.
Old Jun 3, 2010 | 08:33 PM
lanceccs's Avatar
lanceccs
Default Setup for mine R888
Seeking advise for my first set of R888,
19" TE37 TA 9.5J +22
19" TE37 TA 10.5J +22
I have been thru 2 sets of Yoko Advan Sport
255/35/19
285/35/19
Current set on
235/35/19
275/35/19
I perfer the looks on the current setup but I cannot find the exact sizes for R888.... I am not sure what should I go with.....
should I go with
Front - 235/35/19
Rear - 265/30/19
Front - 265/30/19
Rear - 295/30/19 or 305/30/19
Old Jun 3, 2010 | 08:57 PM
terrasmak's Avatar
Originally Posted by lanceccs
Front - 265/30/19
Thats your best bet.
To the OP, if you want grip and your basically stock as you say. Get a rear diff, something like an OS Giken. I run 275 NT05's , NA 255hp, and have a hard time stinning them with the diff installed. No problems spinning them when i had the VLSD.
Old Feb 9, 2011 | 11:57 AM
scotts300's Avatar
scotts300
BP - how did this ever turn out?
I'm also interested in chatting about a kit.
Bumpinjeep
Sep 5, 2007 03:40 PM
350Zimo
Jun 2, 2007 08:54 AM
Chad68
May 10, 2007 12:39 PM
chickmagnet
May 21, 2006 06:50 PM
