17" light wheels that clear 13"BBK
Old Mar 28, 2010 | 08:42 AM
QTB's Avatar
QTB
Default 17" light wheels that clear 13"BBK
I'm looking for some ideas on 17" track wheels. There are a few standard wheels I've seen but I'd like something slightly different. I have 13" stop techs and my only requirements are they not be totally fugly, fairly light, and 9-9.5" wide.
Any thoughts?
Old Mar 28, 2010 | 08:48 AM
my350isblack's Avatar
my350isblack
rpf1
Old Mar 28, 2010 | 10:05 AM
terrasmak's Avatar
rpf1
Old Mar 28, 2010 | 10:46 AM
MyV6IsFast3r's Avatar
MyV6IsFast3r
rpf1
okay what about fn01
Old Mar 28, 2010 | 11:20 AM
NismoZ_840's Avatar
NismoZ_840
FYI Apparrently Rpf1 17x9.5 won't fit over OEM brembos unless you can get your offset down to +18 or lower. Then you may have issues getting 275s on them due to fender clearance unless you dial in some camber.
Not sure the OEM Brembo size in inches off the top of my head. I'm running used SSR Comps 17x9.5+35 square and a 5mm spacer for extra front suspenion clearance, only about 2-3mm otherwise with stock suspenion/camber.
Old Mar 28, 2010 | 11:22 AM
Looking cool on the track is a primary concern.
A one-piece mono block wheel is easy to keep clean. Not a lot of corners and crevices to accumulate brake dust and rubber. Keep it simple.
Old Mar 28, 2010 | 12:08 PM
QTB's Avatar
QTB
Originally Posted by NismoZ_840
FYI Rpf1 17x9.5 won't fit over OEM brembos, not sure their size in inches off the top of my head. I'm running used SSR 17x9.5+35 square and a 5mm spacer for extra front suspenion clearance, only about 2-3mm otherwise with stock suspenion/camber.
Not a stock suspension. Which SSR's are you running?
Old Mar 28, 2010 | 02:17 PM
CORNELL's Avatar
CORNELL
17" RPF1 clearing brembos
Old Mar 28, 2010 | 07:42 PM
T_K's Avatar
T_K
With a spacer.
Old Mar 28, 2010 | 07:53 PM
CORNELL's Avatar
CORNELL
nope. 17x9.5 +18 all around no spacers
Old Mar 28, 2010 | 07:54 PM
CORNELL's Avatar
CORNELL
https://my350z.com/forum/wheels-and-...nkei-rpf1.html
Old Mar 28, 2010 | 10:03 PM
QTB's Avatar
QTB
I like it! Do you think they'll clear a larger Stop Tech caliper?
Old Mar 29, 2010 | 05:08 AM
NismoZ_840's Avatar
NismoZ_840
Sorry SSR Comps, fixed above too.
Old Mar 29, 2010 | 05:13 AM
NismoZ_840's Avatar
NismoZ_840
True, but with a camber kit and -3 degrees of camber to clear.
Old Mar 29, 2010 | 06:02 AM
CORNELL's Avatar
CORNELL
camber has no affect on caliper clearance
Old Mar 29, 2010 | 07:02 AM
ExtaZ33's Avatar
ExtaZ33
All sorts of bad information in this thread...
There are 2 different 13" Stoptech kits, the 332mm and 355mm.... and the 355 won't fit under a 17" wheel at all. The width, face type, and offset determine if you will have enough clearance for the wheel spokes.
332mm Stoptechs will fit a 17x9 +35.
Old Mar 29, 2010 | 09:51 AM
NismoZ_840's Avatar
NismoZ_840
My bust, that was for the fender clearance. Agree camber wouldn't change caliper clearance. I've read here at least two people who couldn't fit it over Brembo. I was looking for the same setup but on stock suspension and disappointed when I read they wouldn't work. Will see if I can track them down for reference.
Update: Couldn't find the posts I read, but I did find some other posts that confirm that RPF1s will fit on OEM Brembo as long as you're running +18 or lower offets for 17x9.5 (witnessed in the Ataru link above) or +20 for 17x9 (http://sccaforums.com/forums/thread/205890.aspx). The caveat is that you start to run into fender clearnace issues with 275s for those offsets but Ataru is able to squeeze them in with -3 camber. Sorry for any confusion on this subject but this should clear it up.
Doesn't matter the OP is talking different brakes anyways. See #54 in the Ataru link above from ScottS300 for more info. He's run a number of 17" track setups w/ Stoptech and Brembo BBK so a good source of info as well.
Old Mar 29, 2010 | 10:02 AM
plumpzz's Avatar
plumpzz
5zigens? I have seen those with 13'' bbks, but each bbk differs.
Old Mar 29, 2010 | 10:13 AM
ExtaZ33's Avatar
ExtaZ33
The first thing is, do you have the 332mm or the 355mm 13" Stoptech kit?
Like I said in my first post, I don't think the 355 fits under a 17" wheel at all.
Old Mar 29, 2010 | 12:12 PM
Mike@Blackline's Avatar
Mike@Blackline
355=14", not 13
