Where can I find longer, stronger wheel studs for my 350z?
Old Mar 30, 2010 | 01:20 PM
The Fallen's Avatar
The Fallen
Default Where can I find longer, stronger wheel studs for my 350z?
Im not exactly sure where to look but id like to replace my shitty stock studs with something stronger and possibly longer...
Old Mar 30, 2010 | 01:36 PM
scotts300's Avatar
scotts300
http://www.splparts.com/main4/index.htm
Old Mar 30, 2010 | 03:33 PM
JETPILOT's Avatar
JETPILOT
I have those ARP wheel studs. Since the thread pitch is different you will need to run a different nut and they are longer so you will have to run an open ended lug nut. They suck to install on the rear but worth it if you need them.
Old Mar 31, 2010 | 07:46 PM
shingr's Avatar
shingr
http://www.mynismo.com/products/?id=2574
Old Mar 31, 2010 | 08:19 PM
ekidd's Avatar
ekidd
^ Im running the 60mm's on my rear and 50mm ichiba's up front
Old Mar 31, 2010 | 08:43 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
http://www.z1auto.com/prodmore.asp?m...ls&prodid=4356
in stock, among the stongest on the market, and no need to change the pitch of your lugs (not that it's a big deal). Add your favorite longer lugs, or open ended lugs, and you're set
Old Apr 1, 2010 | 09:14 AM
sry110's Avatar
sry110
How much longer are these than the OEM studs?
Old Apr 1, 2010 | 09:16 AM
Z1 Performance
Former Sponsor
I have no idea how long the stock ones are, sorry. But, the length of these are listed in that link IIRC, and I know we've sold tons of them to members here
Old Apr 1, 2010 | 07:14 PM
JETPILOT's Avatar
JETPILOT
Those NISMO studs are the same metal as OEM. They aren't any stronger.
Old Dec 18, 2010 | 01:13 PM
GWord256's Avatar
GWord256
Any objections to cutting the ends short to fit them on the rear hub without having to take the hub off?
Old Dec 18, 2010 | 06:25 PM
terrasmak's Avatar
no need, just remove the e brake cable and feed the stud thru
JjL
East Canada
Jun 12, 2019 03:04 AM
RWDBajan
Sep 17, 2015 04:52 PM
Beater350z
Sep 9, 2015 03:36 PM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
