buying new rims this mornign what offset works
Old Mar 31, 2010 | 12:51 AM
crsracing19's Avatar
crsracing19
Default buying new rims this mornign what offset works
ok im buying some enkei nto3+m wheels in the morning 18in 10.5 rear 9.5 front
what offset will work well and hopefully wont rub im new to rim specs so any help would be great also what tire sizes would well for this setup
Old Mar 31, 2010 | 01:16 AM
Spork's Avatar
Spork
Old Mar 31, 2010 | 01:23 AM
calin's Avatar
calin
You probably should have done a bit more research beforehand. Buying wheels without knowing proper offsets FTL.
Old Mar 31, 2010 | 01:42 AM
crsracing19
im buying them in afew hours iv gone through a few threads but every on is very undecided i just need two solid number for front and rear that wont rub or give me any problems
Old Mar 31, 2010 | 01:51 AM
calin's Avatar
calin
19x10 -20 / 19x11.5 -35
If that's not flush enough, you can add some spacers all around
Old Mar 31, 2010 | 02:06 AM
crsracing19
i was going with 18x10.5 +33/35 and 18x9.5 im not sure yet
Old Mar 31, 2010 | 03:24 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
+27 front/+30 rear
/thread
Old Mar 31, 2010 | 03:58 AM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Mar 31, 2010 | 05:51 AM
Thermal1's Avatar
Thermal1
The enkei website has 18x9.5 +27 and 18x10.5 +30
That is the best you can do with those wheels
Old Mar 31, 2010 | 06:21 AM
scotts300's Avatar
scotts300
Depends what look you're going for and what size tires you plan to run.
Old Mar 31, 2010 | 07:58 AM
crsracing19
im looking at running 265/35/18 295/3518
im just want something that looks clean and wont give me any problems with rubing
Old Mar 31, 2010 | 08:25 AM
terrasmak's Avatar
+27 front and +30 rear , and bump the front tire to a 275/35 for better handling. My car will be down there tomorrow, i have the same wheels on it.
Old Mar 31, 2010 | 08:45 AM
TheBlue350z's Avatar
TheBlue350z
i ordered the same wheels... i wanted to put 15mm spacers all the way around..would this work... Rear295/35/18) +15 offset Front265/35/18)+12 offset.. I have Tanabe GF210
Old Mar 31, 2010 | 09:05 AM
zerafian's Avatar
zerafian
dont rush into buying rims, youll end up screwing yourself by making all the wrong choices.
Old Mar 31, 2010 | 10:24 AM
terrasmak's Avatar
Doubt the rear will work, actually doubt either will work with that much spacer. Just get the wheels and tires. Then space them where needed.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
