Which tire sensor on display is what?
Old Apr 6, 2010 | 12:43 PM
JOMZSHAKES's Avatar
JOMZSHAKES
Default Which tire sensor on display is what?
two of my tpms sensors are out, theyve been rolling around in my tires for about 15,000 miles without a mount.i bought a mount kit "$40"...
one TPMS reads "0",
one TPMS reads "--"
the other 2 are fine.
i found a 4 pack to buy for $311, the other two work but are badly damaged and i plan on owning the car for a long time.
i want to get 4 new ones, but if i want to see which tires have the bad sensors
my gauge pod for tires show F: (34) "a" /// R: (0) "c"
------------------------------(--) "b" /// (34) "d"
is "a" front left or front right???
is "c" rear left or rear right???
any ideas on how to get a good deal on this, ??
Old Apr 6, 2010 | 01:02 PM
Guilty1s's Avatar
Guilty1s
You can pick some up in the market place cheaper... usually see them go for ~100 a set.
Old Apr 6, 2010 | 01:25 PM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
We also carry the oem sensors.
Old Apr 6, 2010 | 02:16 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
You'll have to check the sensors to find out which-one-is-which.
What I did, was put a bizarre amount of air in one, either high or low. High is probably better. Then drive around to get it to read, then you can figure out which one each is.
The reason I say this, it that when I had my tires balanced one time, the tire store swapped my rims side to side. Even though I told them not to. So, what had been the RR, was now the LR and the same for the front.
Old Apr 6, 2010 | 02:23 PM
britalia's Avatar
britalia
A is front right for sure. I deduced this from a slow leak I once had. An educated guess for C would be rear right... just an assumption based on the fact that those cunning japs like to read right to left.
Old Apr 6, 2010 | 02:46 PM
350junkie's Avatar
350junkie
maybe whoever put the tires on last time broke them?
also here's a set of 4 bnib for 100$
https://my350z.com/forum/texas-marke...tmps-bnib.html
also the sellers a good guy
Old Apr 6, 2010 | 03:16 PM
JOMZSHAKES's Avatar
JOMZSHAKES
pm sent
i will definatly be buying these,
thanks eeeerybody
Old Apr 6, 2010 | 03:29 PM
TreeFiddyZee
Do WHAAAAT!?
Not if the wheels get moved.
Old Apr 6, 2010 | 03:32 PM
dmroberson's Avatar
dmroberson
Mine is oriented as such:
top reading is passenger side,
bottom is driver side.
Made sense for me, since the bottom side has an < in it. Helps me remember... lol.
Old Apr 7, 2010 | 05:29 AM
F34RL355's Avatar
F34RL355
where do i find the reading on my 08? all i have is a tpms warning on my dash where can i actually see my pressures
Old Apr 7, 2010 | 06:18 AM
TreeFiddyZee
Do WHAAAAT!?
'08 doesn't have a pressure reading like the earlier models.
Old Apr 8, 2010 | 05:41 AM
F34RL355's Avatar
F34RL355
ya i didnt think so.. just a warning light in the dash after which i have to check all four tires cause no idea which one is low lawl
Tochigi_236
Sep 27, 2015 03:40 PM
