Wheels & Tires Wheels, Tires, Big Brakes, Coilovers, etc...
WEDDSPORT Lightweight JDM Tuning Wheels - In Stock Special
Old Jun 20, 2010 | 05:01 AM
RavSpec's Avatar
RavSpec
Vendor - Former Vendor
Default WEDDSPORT Lightweight JDM Tuning Wheels - In Stock Special
Ask for tire package !! ** In Stock Special
WEDSSPORT TC105N - 18x9.5 10mm offset 5x114.3 Bronze ** 17.6 lbs
WEDSSPORT TC105N - 18x9.5 35mm offset 5x114.3 Bronze ** 17.6 lbs
WEDSSPORT TC105N - 18x10.5 12mm offset 5x114.3 Bronze ** 18.4 lbs
WEDSSPORT SA55M - 18x9.0 20mm offset, 5x114.3 Gun Metal or Black** 19.5 lbs
WEDSSPORT SA55M - 18x9.0 20mm offset, 5x114.3 Blue Accent ** 19.5 lbs
WEDSSPORT SA55M - 18x9.0 20mm offset, 5x114.3 Red Accent ** 19.5 lbs
WEDSSPORT SA55M - 18x9.0 36mm offset, 5x114.3, Gun Metal ** 19.5 lbs
WEDSSPORT SA55M - 18x9.0 36mm offset, 5x114.3 Blue Accent ** 19.5 lbs
WEDSSPORT SA55M - 18x10.0 18mm offset, 5x114.3, Gun Metal or Black ** 20.4 lbs
WEDSSPORT SA55M - 18x10.0 18mm offset, 5x114.3, Blue Accent ** 20.4 lbs
WEDSSPORT SA55M - 18x10.0 18mm offset, 5x114.3, Red Accent ** 20.4 lbs
WEDSSPORT SA55M - 18x10.0 36mm offset, 5x114.3, Gun Metal ** 20.4 lbs
WEDSSPORT SA55M - 19x 9.5 +15mm or +24mm, 5x114.3 Gun Metal ** 21.9 lbs
WEDSSPORT SA55M - 19x19.5 +15mm or +24mm, 5x114.3 Blue Accent ** 22.0 lbs
WEDSSPORT SA67R - 18x9.0 20mm offset, 5x114.3, Gun Metal ** 19.2 lbs
WEDSSPORT SA67R - 18x9.0 36mm offset, 5x114.3, Gun Metal ** 19.2 lbs
WEDSSPORT SA67R - 18x10.0 15mm offset, 5x114.3, Gun Metal ** 20.0 lbs
WEDSSPORT SA67R - 19x8.0 35mm offset, 5x114,3 Gun Metal ** 20.5 lbs
WEDSSPORT SA67R - 19x9.0 +35mm offset, 5x114, Gun Metal ** 20.9 lbs
Hey All:
Weds Japan - one of the top wheel manufacturer in the world. Their wheels line up included lightweight tuning wheels that are being use in JGTC and many racing circuit and luxury sport wheels that are popular on the street of Tokyo. Their newest lightweight tuning wheel series "Wedssport" series included SA55m, TC105N, SA67R and SA70. Using the newest AMF flow form casting technology, Weds Japan bring you the lightest tuning wheel in the market. (see below for AMF definition)
(AMF Technology)
AMF (Advanced Metal Forming) is one variation of rotation forming process that rotates a metal pipe axis and casts the material on the roller.
Casting and Forging
Generally, the advantage of casting is that it melts aluminum alloy at high temperature and pours into a mold to form as one so the designing flexibility on the disc is pretty high thus it’s easy to mass produce and cost effective. On the other hand, from technical stand point, it’s hard to reduce weight since it’s difficult to form into thin metal. Also what was formed through casting is often uneven and particles are not cohesive therefore its strength is not good enough. On the other side, forged wheels are made by running a lump of aluminum or alloy into high-pressure pressing machine thus aluminum particles spread and formed according to wheel shape and it is stronger (Fiber Flow). Because of the way they are produced, forged wheels can be made light-weight. It seems like it’s perfect but there is a definite weakness of “It’s not flexible from design perspective. It has already been explained, forging process uses high rate of weight to form the shape consequently, it is not suitable for complicated cosmetic face design. Forging also has a disadvantage of being more expensive due to multi-processing.
"New method of manufacturing process" to make up for the weakness is born.
In AMF, first of all, simultaneously cast rim and disc. Secondary, cast disc (= rim material) is to be put through wheel-only spinning processor and roll the rim. It realizes more flexible and tenacious strength by having aluminum material’s crystal and macro formation get further detailed through being forged in this process. As a result, high-strength rim with “stretch strength,” “durability,” and “spread” which are basic characters required for aluminum wheels, is born. Now it is possible to create high-precision rim that is seamless tube as compared to the type that forms a sheet material into a ring through welding. AMF on disc surface is normally casted, it keeps design-flexibility, but it contributes to reduction of under spring load because the rim-part is spread thin as much as possible by spinning machine. Such new method of manufacturing process method is AMF which has the merit of both casting and forging. AMF was newly created the WedsSport brand concept “Faster, Safer.” New generation technology improved in motor sports enters the scene with superb performance.
Old Jun 20, 2010 | 05:02 AM
RavSpec's Avatar
RavSpec
WEDSSPORT SA55M 19x9.5 front and 19x10.5 Rear (in stock now)
+15mm or +24mm offset for both size available
Blue Accent or Gun Metal
Aggressive Concave Face
*** Ask For Tire Package ***
Old Jun 20, 2010 | 05:03 AM
RavSpec's Avatar
RavSpec
WEDSSPORT SA55M (Gun Metal and Red Accent) Color.
Old Jun 20, 2010 | 06:39 AM
dkmesa350z's Avatar
dkmesa350z
SA-67R in polished finish 18 x 9 +20 / 18 x 10 +15?
Old Jun 20, 2010 | 12:27 PM
lowcel's Avatar
lowcel
Price shipped to 25312 please.
Old Jun 30, 2010 | 11:47 AM
RavSpec's Avatar
RavSpec
all PM replied !
Old Jun 30, 2010 | 02:53 PM
CORNELL's Avatar
CORNELL
can you get the SA70TT? if so im interested in the 18x10 +12 front and 18x11 +12 rear shipped to 77064 thanks
Old Jun 30, 2010 | 04:35 PM
RavSpec's Avatar
RavSpec
that should be discontinued ... Now it's only SA70 (w/o the rivets)
Old Jul 30, 2010 | 07:20 PM
RavSpec's Avatar
RavSpec
WEDSSPORT SA55M Custom Red Accent (In Stock Now) ** Super Aggressive Concave Face
One set on special clearance
18x9.0 +20mm Front / 18x10.0 +18mm Rear
With Falken 452 Tires - $2599 Shipped to Lower 48 states
Old Jul 30, 2010 | 08:46 PM
cliffrlp's Avatar
cliffrlp
[QUOTE=RavSpec;8560712]
price w/o tires shipped to 32608
Old Jul 31, 2010 | 11:33 AM
RavSpec's Avatar
RavSpec
Pm sent only one set with that price.
Old Jul 31, 2010 | 01:26 PM
NA&CH's Avatar
NA&CH
Originally Posted by RavSpec
Price on these. Will a 18x10 +18 fit up front on track models(brembo)
If so 18x10 4 corners. 265-285 tires combo.
Thank you,
Chris
Old Jan 5, 2011 | 08:07 PM
RavSpec's Avatar
RavSpec
WEDSSPORT SA67R , RR Face, 18x10.0 +15mm offset, Gun Metal Color
Old Jan 14, 2011 | 08:08 PM
RavSpec's Avatar
RavSpec
Old Feb 18, 2011 | 09:18 PM
RavSpec's Avatar
RavSpec
quick bump !!
Old Feb 20, 2011 | 07:23 AM
styy81's Avatar
styy81
hi ravspec,
pls pm me the price for SA-55M model. usual colour and indent blue model - 19x9/19x10 and 18x9/18x10
thanks.
Old Feb 20, 2011 | 07:54 AM
RavSpec's Avatar
RavSpec
PM sent !
Old Feb 21, 2011 | 05:24 AM
gohandbz88's Avatar
gohandbz88
How much with tire package shipped to 60616?
Tire sizes 245/40/18 and 275/40/18
Old Feb 21, 2011 | 08:13 AM
RavSpec's Avatar
RavSpec
$2850 shipped to 60616, either 245/40 or 275/40 tires.
Old Mar 11, 2011 | 06:38 PM
RavSpec's Avatar
RavSpec
quick bump , more inventory in coming !
