Volk TE37 Thread
Old May 16, 2013 | 09:47 PM
  #981
S13 S1lvia's Avatar
S13 S1lvia
19x9 +25 19x10 +25
Old May 16, 2013 | 10:43 PM
  #982
angelo350z's Avatar
angelo350z
Nice. You running spacers?
Old May 17, 2013 | 02:32 PM
  #983
S13 S1lvia's Avatar
S13 S1lvia
Suprisingly not, they fill the guards really well for the specs. I swear the sticker in them must be a miss-print.
Old May 17, 2013 | 02:35 PM
  #984
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Those are odd sizes. Love that color combo though
Old May 17, 2013 | 02:36 PM
  #985
AdvanZ33's Avatar
AdvanZ33
What lug nuts are those S13?
Old May 17, 2013 | 04:00 PM
  #986
S13 S1lvia's Avatar
S13 S1lvia
Rays Duralumin lock/lug nuts. Order my centre caps for them next week I think, only got the car two weeks ago.
Old May 18, 2013 | 12:27 AM
  #987
taryon's Avatar
taryon
Looks great S13 S1lvia!
Old May 19, 2013 | 06:01 PM
  #988
sry110's Avatar
sry110
Old May 19, 2013 | 07:54 PM
  #989
The_Laughing_Man's Avatar
The_Laughing_Man
^ Damn, that is sexy.
Old May 20, 2013 | 04:30 AM
  #990
6SpeedCarbon's Avatar
6SpeedCarbon
Sry110 nice ride what's the specs on your rims and tires pls
Old May 20, 2013 | 04:52 AM
  #991
angelo350z's Avatar
angelo350z
You never fail to impress sry110 .
Old May 20, 2013 | 06:28 AM
  #992
sry110's Avatar
sry110
Thanks!
I appreciate it! Specs are as follows:
Volk LE37t in Mercury Silver
Front: 19x9.5 +22 with 10mm spacer, Hankook V12 245/35/19
Rear: 19x10.5 +22 with 15mm spacer, Hankook V12 275/35/19
Old May 21, 2013 | 05:56 PM
  #993
teeohfosho's Avatar
teeohfosho
Originally Posted by sry110
It looks like it would, although it might be close, but I never actually tried it. For whatever it's worth, I'm currently running 19x9.5 +22 fronts with 10mm spacer and 245/35/19 tires, and it looks like I could bump out another 5mm and still be OK. I imagine you are using 255/35 up front, which are theoretically another 5mm wider in each direction than my 245/35 (which of course varies by manufacturer and style), but just from eye-balling it I think 245/35/19 at +7 net offset will work, and therefore 255/35/19 at +12 offset should work too.
EDIT: My main concern is that there is a metal screw clip just about top dead center connected to the fender liner in the front wheel well, just above where the sheet metal wraps into the wheel well. There is a pan head type screw that you can remove from the clip which gives a little extra space, but I'm still worried about the tire hitting the screw clip if I space them out any farther. This weekend I may actually be testing this out, so if I end up doing that I'll let you know what I find.
EDIT#2: Another consideration is that 255/35 tires have a more "vertical" sidewall than 245/35 tires (assuming they are the same make/model of tire). So even when spaced out farther, the skinnier tire with more "slanted" sidewall will have more forgiveness for fender clearance as the wheel cambers in while traveling up into the fender well. So camber angles and ride height being equal, I may have more luck at 245/35 +7 than you would have with 255/35 +12. But I'm really just speculating all of this.
This has been awhile and I can't find any new posts. Anybody running / know of someone running a 255/35 +12 lowered on coils ? I plan on lowering / running it as flush / minimal poke as I can without running too much camber or rubbing.
Old May 22, 2013 | 08:43 AM
  #994
sry110's Avatar
sry110
I still don't have an answer to this question, but I'm thinking the safe bet at +12 offset is the 245/35/19 tire size.
Using this pic again as a reference, here is 245/35/19 Hankook V12 at +12 net offset. You can see that the front tire is getting close to the fender, and that the wheel rim itself is already sitting outboard of the fender (i.e. poking). Also, in this photo the rear is 275/35/19 at +7 net offset. If I went any lower offset up front, I would want to lower the rear offset also to avoid the appearance of having my front wheels sitting out noticeably farther than my rears. Maybe that's just personal preference, though.
Old May 22, 2013 | 10:12 AM
  #995
teeohfosho's Avatar
teeohfosho
Sounds good. I am planning on running +7 in the back with a 295/30/19 tire, so I am currently debating on whether I should get a 10mm spacer or 5mm for the front with a 255/35/19 tire. Currently am at +22 both front and back.
Old May 22, 2013 | 10:37 AM
  #996
teeohfosho's Avatar
teeohfosho
While I'm on here, does anyone know the specs on this picture ? Saved it from somewhere on this forum, forgot where.
Old May 22, 2013 | 10:46 AM
  #997
AdvanZ33's Avatar
AdvanZ33
That looks like SuperBlack350Z's old car. Shoot him a PM, he's still around.
Old May 22, 2013 | 01:08 PM
  #998
teeohfosho's Avatar
teeohfosho
Talking to him now, thanks.
Old May 23, 2013 | 03:27 PM
  #999
AdvanZ33's Avatar
AdvanZ33
Old Jun 10, 2013 | 03:36 PM
  #1000
murders's Avatar
murders
Looking for te37 with +12 offset, im me with color and price.
