Getting an alignment
Old Jul 31, 2010 | 09:34 PM
yella's Avatar
yella
Default Getting an alignment
sup everyone i got a 03 350
my wheels are 18x9.5 +15 18x10.5 +18 tires are nitto nt-05 265/35/18 295/35/18
rears are rolled...what specs should i tell them to sit it at? got cusco a arms and spc cambers. i need it where i can drive it everyday without any problems
Old Jul 31, 2010 | 09:38 PM
JasonZ-YA's Avatar
JasonZ-YA
center of stock specs.
-J
Old Jul 31, 2010 | 10:15 PM
yella's Avatar
yella
so stock specs i shouldnt have any rubbing problems right?
Can i put my track wheels on then go get it aligned and come home then put my wheels back on then?
Old Jul 31, 2010 | 10:59 PM
terrasmak's Avatar
Use the wheel and tires for alignment that you want the most out of. I would use the street set.
For the rear, have them go near -2 camber, its still in spec and will keep you from having a rubbing problem. Since you have track wheels ( i think your talking about the ones you use on the roadcourse) have them align the front to -1.5 to -2 depending on your needs for you track driving.
Old Aug 1, 2010 | 12:03 AM
I assume this set-up is for looks not handling? OEM specs are fine.
Old Aug 1, 2010 | 07:53 AM
yella's Avatar
yella
No I was talking about oem 18" track wheels
I want it set where it won't rub... It's setup for the track now the fronts are -2 I forgot what the rears were set at. The car is being driven on the streets now so i wanted to get alignment for the streets.
emooheo
Oct 14, 2015 08:58 AM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
