What size spacers?
Old Aug 9, 2010 | 08:21 AM
DCshortyG123's Avatar
DCshortyG123
Default What size spacers?
Hey guys ive done some research but could not find a good answer to this. Im looking into getting spacers but im not sure what size i need up front and rear.
Im running ssr-gt 7 wheels
19x8.5 front
19x9.5 rear
They are wrapped in BFG KDW2s 245/35/19 front 275/35/19 rear
I will be getting a fender roll i just dont know what size spacers to get.
I also dont know the offsets but here are some picc
Thanks
Attached Thumbnails What size spacers?-005.jpg   What size spacers?-007.jpg   What size spacers?-009.jpg
Old Aug 9, 2010 | 08:41 AM
microsteve40's Avatar
microsteve40
Know it all
You really need more info before you can decide on a set of spacers. At the bare minimum, you should find the offset. Have you looked at the back of the wheel to see if it's stamped on there? This has been the case on the aftermarket wheels I've had.
Other than that, it depends on what kind of fitment you are going for...I'd suggest setting your camber where you want it first, then simply measure the difference b/t where your wheel/tire is at (relative to your fender) and where you want it to be, and get the closest size spacer to that.
Old Aug 9, 2010 | 08:42 AM
ksmoore's Avatar
ksmoore
looking at it, im going to say 15mm
Old Aug 9, 2010 | 09:04 AM
angelo350z's Avatar
angelo350z
I say 15mm at the most in the rear and 20mm at the most up front.
Old Aug 9, 2010 | 09:31 AM
POWUH's Avatar
POWUH
25-30 those offsets look horrible
Old Aug 9, 2010 | 09:44 AM
angelo350z's Avatar
angelo350z
We're not helping much, are we?
Old Aug 9, 2010 | 10:14 AM
How far do you want to move the wheels? 10mm? 20m? 30mm? It is not that hard to figure out.
Old Aug 9, 2010 | 11:23 AM
scotts300's Avatar
scotts300
SSRs have the offsets stamped inside the wheel and/or on a sticker on the wheel barrel.
Old Aug 9, 2010 | 11:40 AM
TheFarmer's Avatar
TheFarmer
Old Aug 9, 2010 | 11:56 AM
sdZ33's Avatar
sdZ33
measure accordingly and cut
Old Aug 9, 2010 | 12:55 PM
DCshortyG123
the offsets are not stamped on the inside of the wheels for some reason. And yes i know the offsets are horrible, thats why im trying to do something about them
sales@czp
Sep 23, 2019 03:30 PM
