volk sf challenge 10.5 question
Old Nov 11, 2003 | 04:50 PM
hugo1669's Avatar
hugo1669
Default volk sf challenge 10.5 question
Can someone tell me do the fenders have to be rolled if you are using a 10.5 rear sf challenge rim?
Old Nov 11, 2003 | 05:55 PM
hugo1669's Avatar
hugo1669
And if you don't have to roll the fenders what offsets will give a wide lip.
Old Nov 11, 2003 | 06:29 PM
robertchen's Avatar
robertchen
yes, if your car is lowered, no if your car is not lowered... if you dip alot, it will rub... depends on tires too, use SO3 always.. =) i have the sf challenge 9.5 and 10.5 gold...
Old Nov 11, 2003 | 06:47 PM
hugo1669's Avatar
hugo1669
As for now I'm not going to lower the car. Also what size are your tires and what are your offsets. Thanks
Old Nov 12, 2003 | 10:59 PM
tekkensux's Avatar
tekkensux
RobChen: Those are NICE rims! They look sweet on your ride.
Gold on white is pimp. Love the Brake System too-SWEET. Hey, you know what kinda tuner lugs (those light blue ones) the Esprit Car uses on its SF CHALLENGES? Those look pretty sweet.
hugo: +15 fronts, +23 rears for ideal setup in 9.5 and 10.5.
Old Mar 16, 2004 | 07:16 PM
MTL350z's Avatar
MTL350z
I have the same setup +15 fronts, +23 rears in 9.5 and 10.5
Will lower with Eibach and planning on running with Toyo T1-S
245-35 fronts, 275-35 rears, do i have to roll the fenders?
P.S my wheels will not arrive in another 4 weeks
Old Mar 17, 2004 | 03:03 PM
2NthuZd's Avatar
2NthuZd
What about with the 8.5's and 9.5's?
Old Mar 28, 2004 | 06:14 PM
TXREFI's Avatar
TXREFI
What does roll your fenders, mean?
Old Mar 28, 2004 | 09:51 PM
ZISBAK's Avatar
ZISBAK
here is a picture that kind of show you what they are talking about. You want to push that strip upward, so that the tire won't rub!
Old Mar 29, 2004 | 04:33 AM
hugo1669's Avatar
hugo1669
The inner lip of the fender is rolled up/ inward to allow for more clearance of the tire. In my area body shops charge between $100-$275 to do it.
Old Mar 29, 2004 | 04:34 AM
zeroday's Avatar
zeroday
ugh...i really wouldnt do the baseball bat method unless you want your wheel well paint to start chipping off. they actually have fender rolling equipment out there...if you do this you're suposed to heat the area with a heat gun before you start rolling too.
issyz
Jul 2, 2017 03:04 PM
