street radials-drag radials
I use what m/t calls street radials. I'm very happy with my et times, but about 1/3, of the time the tires loose traction to a point where the run is over in first gear. Anyone here tried Hoosier drag radials?, M/T drag radials? M & H dot cheater slicks? Any suggestions on getting traction coming out above 4,000 rpm ????
You don't get the bias tire / non-bias tire "wobble" until at least 115 or 120mph, in my experience. When I run the ET Streets with regular street tires in the front on the 350, it's no problem. When I run the same in my 300ZX TT, I get quite a bit of tail wobble between 120 and 130mph.
To hell with the Top-25 here. Get some bad *** slicks and a couple of spare axles.
[QUOTE=davidv;8630995]
es.
[/QUO
What the hell are those???? Screw the axles. I want to race that 370z guy in Florida this winter. Need traction & 10 more HP......
es.
[/QUOWhat the hell are those???? Screw the axles. I want to race that 370z guy in Florida this winter. Need traction & 10 more HP......
Last time out, I left @4500RPM and smoked them like street tires. 22psi in tire. I've tried lower pressure, but then get some wheel hop on the 1-2 shift.
I've found the only why to get just an ok launch, is 3000RPM max and Feather the Throttle.
Pro's what to chim in.....
Long burnout. Run them down to 12-14psi....particularly the 60 sidewall tires. Allows the sidewall to "wrinkle" and lay a larger contact patch, etc. I know people personally that have run 8's on the 275/60 MT DR.
I have exactly the same problem. I don't get it, I see guys with 900Hp on the same tire (275/60/15) with no problems.
This Tire I'm using is a M/T Street Radial not Drag Radial, they are two completly different tires. What tire are you talking about?
Thanks
TimRod
This tire?
http://www.summitracing.com/parts/MTT-3754R/
It may say "street radial", but it IS a drag radial. It IS a 0 tread wear tire. This IS the very tire I am talking about.
Also, I used the 26" version on my car and pulled several mid 1.8's on them. I just lacked power to go any lower.
Thanks, just verifying, because M/T makes a Tire Called Drag Radial that is NOT street Legal.
Thanks again
http://www.mickeythompsontires.com/s...m=ETDragRadial
Thanks again
BTW, depending on how your tires were stored (drag racing tires must be stored in a certain way to preserve the compound), the compound may have hardened, lowering its ability to "hook."
Ya, I've just been on the M/T site, reading about that very thing. I've only got 6 runs on them, but they are 2-1/2 years old. They were stored inside my house in heavy black bags.
Like most road racing DOT/Non-DOT slicks and DOT/Non-DOT drag slicks....the MT's need to be stored in warmish (above 40f) area. The compound gets hard and far less supple if exposed to freezing temps. As long as they are well stored they should be fine. Just roast 'em....and you should find them more than enough tire.
