15" wheels on 08 350z
Old Sep 1, 2010 | 02:50 PM
andre12031948's Avatar
andre12031948
Default 15" wheels on 08 350z
I'm trying to find out if I can use 15" wheels on my 08 350z. Since 2 tires & wheels can cost more than a bit of $$$$, I'd like to be sure. There are also many type & fits of 15" wheels. Anyone here actually used & can recommend some brands & styles.
Thanks
Old Sep 1, 2010 | 02:53 PM
fatboy.yoshi's Avatar
fatboy.yoshi
15?...you might be able to find 18's for the same price of 15's
Old Sep 1, 2010 | 03:00 PM
hwcustoms's Avatar
hwcustoms
Edit*
Old Sep 1, 2010 | 03:06 PM
theianmcdougall's Avatar
theianmcdougall
hahaha i know i drifted on s14 stocker's once in the rear 16's
but if you really want to ride around on 15's and not have people laugh at you your highly mistaken
Old Sep 1, 2010 | 03:11 PM
350sexZ's Avatar
350sexZ
15 that's kind of small don't you think. Its not a honda. Why not try 17 atleast?
Old Sep 1, 2010 | 03:13 PM
15 inch wheels are well covered in the drag racing forum.
Old Sep 1, 2010 | 03:17 PM
03threefiftyz's Avatar
03threefiftyz
As long as you don't have brembo's you can....I assume this is what you want to mount your slicks on? I ran 15's on the back w/o issue. You just need to make sure you get the correct bolt pattern, offset, and backspacing.
Old Sep 1, 2010 | 03:18 PM
andre12031948
Either I wasn't very clear, or you guys have a problem with reading/understanding
Old Sep 1, 2010 | 03:25 PM
andre12031948
Did you use Weld wheels? Model? Even the tech guy wasn't sure. I don't want to buy a set of 15" slicks & wheels only to find out they don't fit. 08 might hae different brakes set up than sime older ones.
Old Sep 1, 2010 | 03:46 PM
03threefiftyz
Yes, I used welds. +25 offest, 5x4.5" bolt pattern, and 5.5" backspacing. Keep in mind this was with only an 8" wide wheel. I still ran the 275/50/15 MT DR's without issue, and it is a common set-up.
Link:
http://www.summitracing.com/parts/WLD-96-58210/
Pics on car from early last year:
Old Sep 1, 2010 | 03:59 PM
hwcustoms's Avatar
hwcustoms
If you would have said 15" wheels for drag or track use I would have understood. Meh bad......
Old Sep 1, 2010 | 04:36 PM
andre12031948
meh bad too
Old Sep 1, 2010 | 04:45 PM
andre12031948
Link:
Thats what I've been looking at. Any issues with log nuts?
Old Sep 1, 2010 | 05:00 PM
03threefiftyz
No, I used the lugs from weld. They are fairly long closed end lugs. I just checked them every few runs or so.
Old Sep 1, 2010 | 05:13 PM
Spork's Avatar
Spork
Log nuts.
Anyone have issues with them?
Old Sep 1, 2010 | 05:19 PM
andre12031948
Thanks-I'm going to give it a shot-in a couple of weeks you'll have to make a change to the list-12.8 coming
If things go well, I'd like to go race that 370z guy in Florida. Need a mod for 10 more hp-nah, Ill just change the oil
RiujinZero
Apr 16, 2021 11:31 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
davidm350
Oct 31, 2015 02:28 PM
pdexta
Sep 14, 2015 11:27 AM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
