20" Tires
Old Nov 13, 2003 | 04:32 PM
snook789's Avatar
snook789
Question 20" Tires ?
I am getting 20 inch wheels x 8.5 and x 10
Tire selection is slim.
I wanted to go with S0-3 245/35 275/35. but those sizes are not available in 20's
Only 245/35 275/30
If my calculations are correct, that would make the front tire 26.7 inches high and the rears 26.8 inches high.
How would that be ?
Anyone have a recommendation for a 35/20 series tires ?
Old Nov 13, 2003 | 05:37 PM
ares's Avatar
ares
Veteran
35 series? on a 20" rim? you need like 30series front and back. 35 is what they use on 19" rims. 20"s should be 30 series without me working out the calculations.
Old Nov 13, 2003 | 05:38 PM
tylerdurden's Avatar
tylerdurden
Might cause problems if you have a VDC equiped car. Read some of the threads on sizing problems.
Old Nov 13, 2003 | 06:05 PM
PANCHOVILLA's Avatar
PANCHOVILLA
I have 245/35/20 on a 9.0,275/35/20 on a 10.0 .This set up seems to work great.
Old Nov 13, 2003 | 06:18 PM
ares's Avatar
ares
Veteran
those sizes would put your overall diameter a full inch larger than stock... you WILL feel a difference in speed with a difference like that.
Old Nov 14, 2003 | 01:33 AM
snook789's Avatar
snook789
why is that ?
Old Nov 14, 2003 | 02:16 AM
snook789's Avatar
snook789
more searching I do, it looks like those with 20's are going with
245/35/20 front
275 or 285/30/20 rear
Old Nov 14, 2003 | 06:50 AM
lowrider's Avatar
lowrider
From what I've seen they really don't make the right 20s for our cars. (the Z and the G. The proper sizes would the 245/30 and 275/30. These sizes would maintain the correct stagger. The front, I believe, is the impossible size to find. The reason for this, IMO, is that the tire would have an extremly short sidewall, making the ride very rough, also, you may not have enough load carrying capacity with a 245/30/20. There just is not a good selection of 20s out there. Why not just stick with 19s?
Lou
Old Nov 14, 2003 | 06:56 AM
Beaker02's Avatar
Beaker02
I'm haveing 20" NITTO's installed this week.
Old Nov 14, 2003 | 06:57 AM
Beaker02's Avatar
Beaker02
Make sure the rim offset is right or you'll rub in the back!
Old Nov 14, 2003 | 07:58 AM
snook789's Avatar
snook789
for the back, in stock are either
20 x 10 +38 offset
20 x 10 1/2 31 offset
Which is better ?
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
