Varrstoen Wheels Thread
Old Feb 15, 2016 | 01:34 PM
  #2001
nizmo_0385's Avatar
nizmo_0385
Originally Posted by moment
will 18x9.5 +22 clear the oem track brembos in the front?
will 18x10.5 +22 clear the oem track brembos in the back?
I don't think it will clear. Was told +22 front doesnt clear. However contact varrstoen because they have a new mold where es2 19x9.5 +22 clears brembo where before it didnt. All varrstoen rear wheels clear rear brembo
Old Feb 15, 2016 | 01:50 PM
  #2002
moment's Avatar
moment
Thumbs up
Alright thanks
Old Feb 15, 2016 | 01:54 PM
  #2003
moment's Avatar
moment
Im not even sure if i should go with 22 offset? I have coilovers and my rear fender is rolled, so i might be able to get away with lower offset wheels?
Old Feb 15, 2016 | 02:50 PM
  #2004
nizmo_0385's Avatar
nizmo_0385
Yea id go +12 or +15 whatever it is
Old Feb 15, 2016 | 02:57 PM
  #2005
moment's Avatar
moment
Yeah i just looked it up its 18x9.5 12mm for the front and 18x10.5 15mm
Old Feb 15, 2016 | 03:49 PM
  #2006
moment's Avatar
moment
Will i need camber links to run those offsets? Or will lowering it be enough
Old Feb 15, 2016 | 05:36 PM
  #2007
nizmo_0385's Avatar
nizmo_0385
Not sure i understand.
Old Feb 15, 2016 | 05:38 PM
  #2008
moment's Avatar
moment
Basically will i need camber to run those low offsets?
Old Feb 15, 2016 | 05:58 PM
  #2009
nizmo_0385's Avatar
nizmo_0385
It depends on ride height.
Old Feb 15, 2016 | 06:05 PM
  #2010
moment's Avatar
moment
Right now im at 1-2" lower , maybe ill just play it safe with 22 offset and get spacers if needed
Old Feb 16, 2016 | 10:12 PM
  #2011
nizmo_0385's Avatar
nizmo_0385
Originally Posted by Jazzyfella
Damn I just got my wheels 10.5 R and 9.5 F +22 offset all around ES2 Varrstoen.. The seller Kenny told me +22 might not clear with Brembo's but I didn't listen to him....
He told me they would because theres a new mold...
Do urs not clear?
Old Feb 19, 2016 | 12:43 PM
  #2012
moment's Avatar
moment
well just ordered my wheels, 18x9.5+12 in the front and 18x10.5+15 in the rear.
thinking about going with 245/35 and 265/35
Old Feb 19, 2016 | 07:47 PM
  #2013
nizmo_0385's Avatar
nizmo_0385
I got 18x9.5+22 18x10.5+22.
I just ordered my tires. I got Potenza s-04 Pole Positions F 265/35/ and R 275/35..
Hopefully the front I got isn't to big..
I ran it with room to run 285 up front
Old Feb 19, 2016 | 08:09 PM
  #2014
terrasmak's Avatar
Very common tire width in the track community
Old Feb 29, 2016 | 04:34 PM
  #2015
cincysilvias14's Avatar
cincysilvias14
does anyone know if the es5 wheels clear akebonos?
Old Mar 3, 2016 | 08:47 AM
  #2016
edwinperez951's Avatar
edwinperez951
does anyone know the lip sizes on the es6 18x10.5 and the 19x11? i've read different numbers on different websites.
Old Apr 7, 2016 | 11:00 AM
  #2017
ukraini9mofo's Avatar
ukraini9mofo
Hey guys, I dug thru this forum (believe every single page) however could not find a shot (similar angle) that shows the difference between the following 2 set ups
19x9.5 (ET+12)
19x10.5 (ET+12)
19x9.5 (ET+22)
19x10.5 (ET+22)
Also as far as suggestions, what would you suggest if I play on lowering on S-tech springs, I guess I will need to roll fenders on +12 and it will work without rolling on +22?
Thank you very much .
Old Apr 7, 2016 | 11:13 AM
  #2018
Highway Riding's Avatar
Highway Riding
Go with +22 for the front and +12 for the rear.
Old Apr 7, 2016 | 11:49 AM
  #2019
Arrtus's Avatar
Arrtus
19x9.5 (ET+12)
19x10.5 (ET+12)
19x9.5 (ET+22)
19x10.5 (ET+22)
Hello, I'm running es221's 10.5 rear and 9.5 front with +22 offset all around. I'm currently on stock springs, I'll post some pictures for you when I get home so you can see exactly how it would look.
Old Apr 7, 2016 | 12:10 PM
  #2020
ukraini9mofo
Thank you very much ! If you could take some from top of the fender of both front and rear and one just a regular shot
Cheers!
