Varrstoen Wheels Thread
Old Aug 9, 2016 | 08:45 PM
  #2041
terrasmak's Avatar
Originally Posted by Billyt858
I have a set of varrstoen es2 19 x 9.5 front and 19 x 10.5 rear offset of 12. Tire size 245-35-19 and 275-35-19. I am rubbing when ever going over unlevel road or over a bump more so on the back but also the front. Front is rolled. Need the rear rolled. But it seems<br/>like these wheels are way too wide even if i roll the wheel it will still get in contact with the fender? Any suggestion? adjust the camber ? I am on hotchkis springs.
tires sticking outside of fender<br/>
Roll the rear, it's needed and will be good once rolled. The front just need the top fender liner screw removed of trimmed. I typically trim them for customers , simple and easy, if you still slightly rub up front, grab the fender and slightly give it a pull. You can easily pull the front fenders, just use two hands and evenly pull and it will slowly come out.
Old Aug 10, 2016 | 04:44 AM
  #2042
RichV's Avatar
RichV
I agree. Once you are rolled in the rear it doesn't look like you will be rubbing at all. You are already running enough negative camber, so once rolled you are good.
Old Aug 10, 2016 | 12:54 PM
  #2043
Billyt858's Avatar
Billyt858
i am getting my fenders roll now in the rear at a custom shop. He state if i roll the wheels i'll still rub..options are roll the fenders and curve the fenders a little at your own risk. 2nd option trim a little from the wheel itself.. or maybe i can adjust my toe in alittle.
Old Aug 10, 2016 | 01:45 PM
  #2044
travlee's Avatar
travlee
Master
you wont rub, i would look into another shop
Old Aug 10, 2016 | 01:48 PM
  #2045
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
How in the world would you trim the wheel itself? I was planning on rolling my fenders today but it was rainy... Oh well maybe next week.
Old Aug 10, 2016 | 02:08 PM
  #2046
Billyt858's Avatar
Billyt858
i might have to pull the rear out a little for it to work...$100 more..Can cause uneven surface at your own risk, also 40 perfect chance of paint chip..
Old Aug 10, 2016 | 02:10 PM
  #2047
travlee's Avatar
travlee
Master
just roll it first, see if it rubs (prob wont)
Old Aug 11, 2016 | 03:34 PM
  #2048
Billyt858's Avatar
Billyt858
Had my rear fender rolled. Not pulled. Has not rub since.
Old Aug 11, 2016 | 03:41 PM
  #2049
travlee's Avatar
travlee
Master
we told ya
Old Aug 12, 2016 | 03:38 PM
  #2050
Billyt858's Avatar
Billyt858
Default 350z varrstoen es2 hyperblack
Originally Posted by travlee
we told ya
Here is how it turn out. They are lower on hotchkis springs.
Varrstoen es2 19 inch 9.5F 10.5R tire size 245-35-19 front 275-35-19 rear. On hotchkis spring..Keep factory spec. Must fender roll the rear.
Old Aug 18, 2016 | 01:33 AM
  #2051
sanji1's Avatar
sanji1
Default OEM Brembo clearance
I have 19x9.5 +22 es2 varrstoen's in the front and 19x10.5 +22 in the rear...will the oem brembos clear the wheels or will I need spacers???
Old Aug 18, 2016 | 07:50 AM
  #2052
CK_32's Avatar
CK_32
I keep clicking on the brembo clearance thread... But get sent here...
Old Sep 3, 2016 | 05:21 AM
  #2053
Panman's Avatar
Panman
9.5 and 10.5 +12
Old Sep 3, 2016 | 07:11 AM
  #2054
SPM350Z's Avatar
SPM350Z
Looks great man. Congrats.
Old Oct 3, 2016 | 05:38 PM
  #2055
HellaSuburban's Avatar
HellaSuburban
Hey guys. This is my first Z coming from an S Chassis. I am still trying to figure out the whole wheel fitment thing on the Z33 chassis. I was wondering if 255/35's would fit in the front on a 19x10.5 + 0 Varrstoen ES1 with a super slight pull? Any help would be great, thanks yalllll
Old Oct 3, 2016 | 08:25 PM
  #2056
terrasmak's Avatar
Considering I run a 10.5 +15 up front with a 285/35-18, I'm pretty sure it will fit. You may need to add a hair of extra camber. You will probably want to use camber arms to adjust for the perfect flushness anyhow .
Old Apr 7, 2017 | 09:52 AM
  #2057
midz350's Avatar
midz350
19"×10" +15 255/35
19"×11" +15 295/30
No rubbing on lowering springs with rolled fenders. True coilovers on the way.
Attached Thumbnails Varrstoen Wheels Thread-imag0416.jpg   Varrstoen Wheels Thread-imag0414.jpg   Varrstoen Wheels Thread-imag0415.jpg   Varrstoen Wheels Thread-img_20161110_155959.jpg   Varrstoen Wheels Thread-img_20161110_155953.jpg
Old Apr 7, 2017 | 06:24 PM
  #2058
Bmurray350z's Avatar
Bmurray350z
Looks good. Know your camber specs?
Old Apr 13, 2017 | 08:18 PM
  #2059
midz350's Avatar
midz350
I can't remember because I didn't touch it. It was perfect fit. But will do realignment soon after installing the coilovers and post it here.
Old Aug 3, 2017 | 02:26 AM
  #2060
ohatebasehr's Avatar
ohatebasehr
19x10.5 +22 all around. looking to get spacers soon.
