I got new wheels need help with fitment...
Old Sep 14, 2010 | 08:06 AM
z33jun's Avatar
z33jun
Default I got new wheels need help with fitment...
So ive had my work rezax with some pretty curbed lips.
i decided to purchase new lips (which i did) but now im worried about fit ment.
after the wheels get the lips i think they would be 18*11.5 +7 all around. im sure the rears would fit with a roll but how the hell do i get the front to go.. roll and flare with the camber arms.. is that enough?
wheels were originally 18*9.5 +32 and 18*8.5 +32. i added 5 inch lips all around.
heres a pic of them after the lip.
Old Sep 14, 2010 | 09:30 AM
terrasmak's Avatar
Widebody, or you going to have the south of the border look
Old Sep 14, 2010 | 09:33 AM
JasonZ-YA's Avatar
JasonZ-YA
LOL at "thinking" about this, A.F.T.E.R. buying the lips..........
-J
Old Sep 14, 2010 | 09:34 AM
LVZ053's Avatar
LVZ053
Depends on what tires you have on and how much camber you are running.
I have +7 offset on the fronts and they sit flush with no rub.
Old Sep 14, 2010 | 09:35 AM
Nexx's Avatar
Nexx
camber and 245's in the front should work. youll need to replace tires quite frequently.
Old Sep 14, 2010 | 09:41 AM
terrasmak's Avatar
Use this link http://www.1010tires.com/WheelOffsetCalculator.asp and see what the difference is between your +7 offset and his +7. I will bet you really have no clue what your talking about.
Old Sep 14, 2010 | 09:43 AM
darkzschneider's Avatar
darkzschneider
Slam and they will fit fine.
245/40
Old Sep 14, 2010 | 10:24 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Outer rim = +63.1mm than 18x8.5+32
Inner rim = +13.1mm " "
Old Sep 14, 2010 | 10:35 AM
z33jun's Avatar
z33jun
camber and 245/40 it is.. ill try that out first.. thanks guys
Old Sep 14, 2010 | 10:40 AM
Forget flaring the fenders. Make some new fenders.
Old Sep 14, 2010 | 12:48 PM
LVZ053's Avatar
LVZ053
Use this link http://www.1010tires.com/WheelOffsetCalculator.asp and see what the difference is between your +7 offset and his +7. I will be you really have no clue what your talking about.
Last sentence is hard to understand.
I was implying that there are multiple factors that would determine wheel fitment, not just offsets. My example is one that works.
Old Sep 14, 2010 | 12:57 PM
Voboy's Avatar
Voboy
He's trying to tell you that width and offset go hand and hand, and doubts that you have 11.5" +7.
Old Sep 14, 2010 | 01:11 PM
terrasmak's Avatar
Yup, as mentioned above. Lets say you have a 9.5 inch wide wheel +7 up front, run that thru the link i posted and see the difference. If you did this you would notice his wheel will extend 25mm more in each direction.
BTW crunching numbers off wheels i've tried. He will clear on the inside by about 5mm.
Old Sep 14, 2010 | 03:10 PM
Waiz's Avatar
Waiz
This should be cool, in for installed pics.
Old Sep 14, 2010 | 03:15 PM
z33jun's Avatar
z33jun
the wheels will be the same size.
the lips on the 9.5 are 3 inches +32
the lips on the 8.5 are 2 inches +32
now im removing the lips and adding 5 inch lips to all four
after doing the math i got 11.5 width and +7
wheels and offsets are confusing ahaha
Old Sep 14, 2010 | 03:30 PM
scotts300's Avatar
scotts300
You have 11.5" wide +7 wheels? It does matter.
Old Sep 14, 2010 | 03:42 PM
z33jun's Avatar
z33jun
i plan on running a 245/40 on my 11.5 +7 wheel.
Old Sep 15, 2010 | 06:45 AM
scotts300's Avatar
scotts300
A 245 tire is 9.6" wide, which is almost 2" more narrow than the wheel. Something is wrong here.
Old Sep 15, 2010 | 07:06 AM
z33jun's Avatar
z33jun
Stretch is all the rage the days
Old Sep 15, 2010 | 08:52 AM
scotts300's Avatar
scotts300
Stretch is all the gay these days
Fixed!
