275/30-19 on front
Old Sep 24, 2010 | 10:18 AM
cipric76's Avatar
cipric76
Default 275/30-19 on front
Hello all,
I got 275/30-19 tires mounted on 19x9 +18 wheels on the front and it is rubbing when cornering heavy. I am pretty sure I have seen members with this setup before and I was wondering if anybody can chip in some advice about how they made those fit. I got the setup done 2 days ago and I am not yet sure if I'm rubbing on the suspenssion or the fender but my preliminary analysis seem to suggest the fender. My car is on Nismo S-Tune suspenssion.
My rears are 295/30-19 on 19x10 +22. Feel free to let me know if there were any issues with these too.
Thanks in advance.
Old Sep 24, 2010 | 11:37 AM
DavesZ#3's Avatar
DavesZ#3
Where's it rubbing, inside on control arms/suspension or outside on fender?
Old Sep 24, 2010 | 12:05 PM
cipric76's Avatar
cipric76
If my math is not wrong my new setup vs my old setup should have 3 mm less clearance on the suspenssion side and 27mm less clearance on the fender side of the wheel. From these numbers I would be tempted to say I'm rubing on the fender but I will investigate and be 100% sure a little later. Thank you.
Old Sep 24, 2010 | 12:35 PM
terrasmak's Avatar
Your probably hitting the screw that holds the fender liner in place. Take the screw out , cut it down slightly 1/8 inch and renistall it. The fold it in for more clearance. You can also add an extra 0.1 of camber to help.
Old Sep 24, 2010 | 01:01 PM
If you are rubbing the fender little you can do. You can not move the tire away from the fender.
Old Sep 26, 2010 | 03:12 PM
cipric76's Avatar
cipric76
Ok looks like I got rubbing on the fender side on both front and rear. I wonder if a fender roll would take care of my rubbing issues at the rear. I am still not sure how to handle the fronts rubbing. Any suggestion are welcome.
Old Sep 26, 2010 | 04:19 PM
350zspl's Avatar
350zspl
IS THE car lowered
Old Sep 26, 2010 | 04:36 PM
cipric76's Avatar
cipric76
No. Nismo springs ans shocks which as far as I know are same height as stock.
Old Sep 30, 2010 | 04:04 PM
edgui12's Avatar
edgui12
Damn good thing I saw this thread I wanted to get 295/30/19 for the rear tires as well I think imma wait and see what happens with you
Old Sep 30, 2010 | 07:47 PM
CORNELL's Avatar
CORNELL
Nismo s-tune is said to have a 1" drop compaired to stock. On the fender liner screws you should just take them out. Then remove the square piece of plastic they screw into, shove the liner behind the metal tab and carefull fold the tab onto the liner. If that doesnt help add camber.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
