This is from the aggressive stretch thread...
Old Oct 2, 2010 | 12:27 PM
nismofreak1208's Avatar
nismofreak1208
Default This is from the aggressive stretch thread...
I decided to make a thread in order to pinpoint everyones replies to the advice i'm seeking, in the aggressive stretch thread i posted the following:
oh wheel guru's of my350z.com....I need some assistance for the one who r ballin'. Looking at a set of 19x9.5+24 f/ and 19x11+17 r rims, from my understanding of stretch and fat tires, i'm looking for a look in between meaning i don't want my rear lip to stick out with no tire over it. I'm looking for the middle in mild to agressive stance to go with my coilovers. I've been qouted for a 255/35/19 f and 285/35/19 r, would this achieve what i'm looking for or should i go with 245/35/19 f and 275/35/19 r. Note that the tires i'll be using are hankook evo12's
Ah, well reason those sizes are there is cuz the roads in hawaii are pot hole ridden and I also would like to take it to auto-x once in awhile, yes I've been told about how this makes no sense, but i'd like a comfortable amount of grip during my DD days when i use the Z but still have a sleek look to it in a way, but i'm def not going for SUPER aggressive, thats a def no no for me
Old Oct 2, 2010 | 12:42 PM
hwcustoms's Avatar
hwcustoms
If you are going with a 19x11 I would at least go with a 285. An 11" wheel is 279.4 mm wide, so this would be a good match.
Old Oct 2, 2010 | 01:05 PM
One member says 275 mm is a stretch.
Another says 275 mm is fat.
And another says 275 mm is conservative.
Do not see where these or similar replies are of any value.
Old Oct 2, 2010 | 01:32 PM
Steve-O Z33's Avatar
Steve-O Z33
But then your lip won't be past the sidewall and the nutswingers will ignore you.
Old Oct 2, 2010 | 01:41 PM
hwcustoms's Avatar
hwcustoms
Personally I would go with a 295 or a 305, but it's all about taste. I'm just saying if your wheel is 279 mm wide, why go with a tire smaller in width. The stretched thing never will make sense to me, but it does to some.
Like stated above all these responses are just gonna be a free-for-all. Go with a tire you feel comfortable with op.
Old Oct 2, 2010 | 02:04 PM
Bestswat's Avatar
Bestswat
It depends what you want man, a 305 is a perfect tire size for an 11 inch rim(no stretch and not wide), you can fit a 335 on there if you want the wide tires look. Or a 275 for the stretch look.
Old Oct 2, 2010 | 03:09 PM
Max-G's Avatar
Max-G
285 will be square. 275 will be a super slight stretch. if you want the stretched look get 265. 245 will pretty much be square. i'd go with a 235 up front. but that will look kinda goofy. stretched tires without fitment look weird. throw some 15-20mm spacers on front and it'll be nice.
Old Oct 2, 2010 | 04:00 PM
Amoney47's Avatar
Amoney47
go 235 front 255 rear, or look here tyrestretch.com or here rimtuck.com
Old Oct 2, 2010 | 05:54 PM
CORNELL's Avatar
CORNELL
its going to mostly depend on the brand and model tire you choose. i have an 11" rear wheel and once ran a 275/30/19 bfg kdw that showed some rim poke, but a 255/35/19 michelin ps2 had no rim poke. some sidewalls are stiffer than others. hwcustoms is right if you want stretch without poke dont get a tire smaller than the wheel. i suggest 245/35 f 275/35 r (you probably wanna stay away from falken 452 they poke more rim than stretch) personally i like my rim to poke a little i now run a 245 on my 11
Old Oct 2, 2010 | 05:56 PM
Nexx's Avatar
Nexx
die
Old Oct 2, 2010 | 05:57 PM
Nexx's Avatar
Nexx
11 inch wheel and want an in between look.. go 285/35
Old Oct 2, 2010 | 05:59 PM
2k6-z33's Avatar
2k6-z33
Nexx <3's herrafrush..
Old Oct 2, 2010 | 06:57 PM
terrasmak's Avatar
Slight? 275 is stretched on a 10.5 , hell 245 is stretched on a 9.5
Old Oct 3, 2010 | 06:48 AM
nick350's Avatar
nick350
i have 9.5 255 35 up front and 10.5 285 30 in back and to me that looks stretched im prob gonna try a 305 in the rear and 275 up front. my old wheels were 8.5 245 35 9.5 275 35 and that was perfect. hope this helps
Old Oct 3, 2010 | 06:50 AM
nick350's Avatar
nick350
to me it looks like the 10.5 should have a 305
Old Oct 3, 2010 | 12:12 PM
vrbigdish's Avatar
vrbigdish
Originally Posted by Nexx
die
+1
Old Oct 3, 2010 | 01:08 PM
Max-G's Avatar
Max-G
i've seen a number of brands of 275's on 11's and they've all been mild stretches... then again i do have kind of a different perception of what a "stretch" is than people that love big meats.
Old Oct 3, 2010 | 02:47 PM
Bestswat's Avatar
Bestswat
regardless 275 will stretch on a 10.5" rim or 11" rim
Old Oct 3, 2010 | 03:04 PM
litoflow's Avatar
litoflow
Depends what u think stretch is. Im running 245/35 on my 11" and its stretch but 275/35 will b perfe t for more traction but not stretch. Just my opinion.
Old Oct 3, 2010 | 03:46 PM
deftoneZ's Avatar
deftoneZ
You could run a 255/35 on the rear of the 11, its a bit of a conservative stretch and what I'm running at the moment. If thats a bit much for you still then consider like a 275 maybe.
best pic I can find at the moment of my rear from this spring before spacers, they are 255/35/19's General Exclaim UHP
