Will 255/40/18 tire fit 18x10 wheel?
Old Nov 17, 2003 | 10:42 PM
WeFlyTonight's Avatar
WeFlyTonight
Default Will 255/40/18 tire fit 18x10 wheel?
What will happen if I put those on.
Old Nov 18, 2003 | 03:16 AM
ragtopz's Avatar
ragtopz
well, according to the discount tire direct post at the top of this section, it is recommended that you either run a 265 or a 275. probably 40 series.
What will happen with the 255's? I dont know. But my friend just had a 245 mounted on a 9.5 and you can see some of the rim exposed that is supposed to be covered by the tire.
You are probably better off going with a wider tire or a narrower rim. Just my opinion... I am no expert, but just from what i have seen and read.
Old Nov 18, 2003 | 03:50 AM
teh215's Avatar
teh215
I agree. I would get the right size tire for the rim. I would be too afraid of the tire coming loose from the rim while I was driving ...
Old Nov 18, 2003 | 10:15 AM
Topics II's Avatar
Topics II
You will be fine if you decide to buy those tires.
Old Nov 18, 2003 | 11:44 AM
ares's Avatar
ares
Veteran
I think it will fit... however I fail to see any good reason to do that combo, either get a thinner rim if you want to run a 255 tire(less weight on the rim for the same amount of traction) or run a wider tire(if your gonna have the wider rim, take advantage of it no?
wide rim narrow tire seems like the worst of both worlds. the idea of having the heavier wider rim is to have more rubber.
Old Nov 18, 2003 | 02:00 PM
John's Avatar
John
I'm glad you said it. What's with all the threads regarding wide wheels and narrow tires as of late? I've replied to about 5 threads in the past 2 days on this subject... I don't get it.
Old Nov 18, 2003 | 02:33 PM
teh215's Avatar
teh215
My guess is that people are trying to save a few bucks on tires by using tires that they alreay have. Given that the Falken FK451s are such a great value, I do not see the point.
Old Nov 18, 2003 | 02:41 PM
ares's Avatar
ares
Veteran
yeah either they wanna use what they have(tho that should be 245s not 255s) or maybe they just cant find the right sizes, which is a reasonable problem, but a bit of a harsh call, Id find the tire somewhere or wait for it till I could get the right one.
but definitly been alot of these threads lately, I know its some kind of style in japan, goes along with the decals, and the 2 different rims on front and back.
Old Nov 18, 2003 | 02:50 PM
John's Avatar
John
You get what you pay for with cheap tires... Does General make a size in 18" yet?
LOL!
Old Nov 18, 2003 | 03:35 PM
WeFlyTonight
I plan on using the tires I already have, which is still new.
Old Nov 18, 2003 | 03:38 PM
WeFlyTonight
Don't forget you are driving a japanese car.
Old Nov 19, 2003 | 02:15 PM
apharmdb's Avatar
apharmdb
Might be because several Japanese tuners such as Top Secret, Amuse, Mine's, etc. are running tire / wheel combos that are near the upper limits with good results. This was certainly the case for me when I started looking around for consistent information regarding tire and wheel sizes and everything kept coming up the same with the Japanese tuners. However with that being said, I haven't seen anything as extreme as 255 on a 10 inch wheel, which is what the original post was about.
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
