Tire Size and Offset Calculator
Old Oct 30, 2010 | 09:39 AM
zayres29's Avatar
zayres29
Default Tire Size and Offset Calculator
my first post i figured i should make it a good one
Offset Calculator
http://www.1010tires.com/WheelOffsetCalculator.asp
Tire Size Calculator
http://www.miata.net/garage/tirecalc.html
Old Oct 30, 2010 | 11:44 AM
RandomHer0's Avatar
RandomHer0
I prefer this one;
http://www.rimsntires.com/rt_specs.jsp
Old Oct 30, 2010 | 12:36 PM
Before I click someone verify this is NOT gay porno. Thanks.
Old Oct 30, 2010 | 12:48 PM
RandomHer0's Avatar
RandomHer0
Its not, they are very common links.
Old Nov 1, 2010 | 07:45 PM
zayres29's Avatar
zayres29
i figured it would be helpful i thought it was really cool when i stumbled across them
Old Nov 1, 2010 | 07:51 PM
It is cool. What is NOT cool is the fact that so many members will ask
What will fit better?
instead of using a calculator and figuring it out.
Old Nov 2, 2010 | 05:21 AM
BoomerZ33's Avatar
BoomerZ33
good links! this should be stickied
Old Nov 2, 2010 | 08:20 AM
scotts300's Avatar
scotts300
Nice links, but one should also know how to calculate tire heights with this:
I don't use an online tire size calculator.
Reported rim width (mm) X tire aspect ratio X 2 (top and bottom sidewall) X (1"/25.4mm) plus wheel height equals total wheel/tire height.
285 * .3 * 2 / 25.4 + 18 = 24.7" tall
Easy to do without the internetz, like when you're at the tire shop and they are trying to tell you that a VDC-equipped car will work with a 275/30/19 rear tire and your 255/35/19 front tires.
Old Nov 2, 2010 | 08:37 AM
JasonZ-YA's Avatar
JasonZ-YA
Offset Calculator
Originally Posted by RandomHer0
will add to the spacers sticky with the other links i have.
good post op.....welcome..
-J
Old Nov 2, 2010 | 10:05 AM
Twenty4's Avatar
Twenty4
willtheyfit.com
Old Oct 13, 2021 | 08:26 AM
ZRight's Avatar
ZRight
Default Need to find replacement rim(s)
When I bought my Z it had 20x9's on Front and 20X10.5's on the rear. I have trashed one of the front rims and cannot find a replacement for it (AXIS Shine Gunmetal). Pic is attached. What I really want to do is replace this rim but it has been discontinued and the company has since gone out of business. Does anybody know where I can find this rim? If not I will have to buy rims all around in which case I will need to know the proper offset for the new rims. With a lowered Z, what would the proper offset be for 20" staggered rims?
The damaged rim
Old Oct 13, 2021 | 09:49 AM
terrasmak's Avatar
The damaged rim
keep a close eye on eBay or buy a fresh set of wheel
