Tires 235-45-18 on all four wheels
Old Nov 18, 2010 | 07:29 AM
daschlag1's Avatar
daschlag1
Default Tires 235-45-18 on all four wheels
I have a 2005 350Z roadster and would like to install 235-45-18 tires on all four of my wheels. I am not too worried about the tires fitting the wheels, but I am concerned about possible imbalance problems from removing the little bolt and spacer, which prevent rear wheels from being inadvertently mounted in the front, from each front rotor. Clearance, between the front tires and the wheelwells and suspension, does not look like a problem. I have read on various forums, about problems with ABS or TCS, which my car has (not VDC), when tires with identical or near-identical ODs are used front and rear. It is time to replace my tires and I would like to buy non-directional tires and be able to rotate any tire to any position. If any of you have tried a similar setup on a similar car, I would really appreciate your input.
Thanks.
Roger
Old Nov 18, 2010 | 08:19 AM
Never mind. I thought this was important to you. Important enough to say “thanks” or simply reply.
gofi
Apr 4, 2022 03:20 PM
dtoma_esq
May 25, 2008 07:41 AM
dtoma_esq
May 24, 2008 11:16 AM
web_creator
Jun 17, 2007 06:37 PM
