Tire Rotation
Old Nov 19, 2003 | 02:32 PM
paulharlacher's Avatar
paulharlacher
Post Tire Rotation
When I first bought my Z I was told by the dealer that you do not rotate the tires. I took it in for a 15,000 mile service and they said that they needed to rotate the tires. They said they would have to dismount them and change sides. Was going to be quite pricey. Does anyone know if I should rotate the tires?
Old Nov 19, 2003 | 05:09 PM
VQ35DES's Avatar
VQ35DES
if your serious...wow, their rippin you off...
all you have to do is take off the lug nuts and swap the left to the right and vise versa then torque them back on
how much were they charging?
Old Nov 19, 2003 | 05:45 PM
zand02max's Avatar
zand02max
I am not a mechanic but I am quite sure, wait I am certain you CANNOT do that. You have to actually take the tire off the rim to do that. You cannot just swap tires from left to right?
Am I right folks?
Old Nov 19, 2003 | 05:53 PM
barrybell's Avatar
barrybell
zand02max is correct, the tires are directional, if you just swap the wheels with dismounting, tire performance will suffer.
Old Nov 19, 2003 | 06:50 PM
cuban350z's Avatar
cuban350z
take your z back to the dealer and tell them that there is a tsb on the tires for making noise while braking. They will dismount and remount the tires for free or they should.
Old Nov 19, 2003 | 07:49 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
The tires are NOT rotated unless they are NON DIRECTIONAL tires. You have Directional tires if you have your stock wheels and tires.
They do what is called a Tire Swap. They take off the actual tire from the rim and re-mount it on the other side. So now the inside of the tire is now on the out side and vice versa.
Drop by Performance Nissan, We will take care of you.
Old Nov 20, 2003 | 12:07 PM
paulharlacher
Thank you all. I think I will take cuban350Z's advise and if that doesn't work I will go to performance Nissan.
Where is Performance Nissan located? I am north of LA in Simi valley.
Thanks again for the help. I read everything you guys post and I learn a lot.
Old Nov 20, 2003 | 05:15 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Are you guys gonna make me get my Stealth model out again to do the demo of the tire swap???
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
