Work VS XX on 2006 350z
Old Dec 24, 2010 | 06:11 PM
240sxll's Avatar
240sxll
Default Work VS XX on 2006 350z
today, I put my Work (18x11-5) on my Z and holy crap they are too big for the car and it looks like it is going to rub the fender... (I am a newbie and new to the Z community) do i need to buy wheel studs or spacer or both. help me out
Old Dec 24, 2010 | 06:18 PM
mariar508's Avatar
mariar508
18x11 -5 front and rear?! Your definitely going to need to roll your fenders and maybe even pull them. Those are some aggressive a** wheels
Old Dec 24, 2010 | 06:19 PM
rps13drift's Avatar
rps13drift
you are definetly gonna have to roll and possibly pull your fenders to fit those size wheels. I also imagine that you will need to stretch your tires aswell. Check out the aggressive stretch/fat tire threads in this section to get an idea of what you are going to have to do. Good luck and sweet wheels!
Old Dec 24, 2010 | 06:20 PM
omsin523's Avatar
omsin523
You should of done some research first. Sounds like your go for the stretch tire look also. Your going to need a roll and pull front and back. And also depends if your on coils,springs, etc
Old Dec 24, 2010 | 06:25 PM
zlatan's Avatar
zlatan
Send them to me
Old Dec 24, 2010 | 07:33 PM
calin's Avatar
calin
You're going to need some crazy camber, especially in the front to pull those off. And like everyone else said, also a roll and fender pull. I would sell those and get something less aggressive (unless that's what you're going for).
Old Dec 24, 2010 | 07:37 PM
mrfobbyaccent's Avatar
mrfobbyaccent
lol
Old Dec 24, 2010 | 09:00 PM
350z_Boi's Avatar
350z_Boi
Roll and pull buddy. Mos def you need to pull... Also go with the stretch tires, it helps with the clearance from fender to tire and if you real don't want to pull as much. Get some camber kits.
Old Dec 24, 2010 | 10:52 PM
Welcome. Can’t tell jack without photos.
Old Dec 25, 2010 | 02:09 AM
terrasmak's Avatar
Return them for proper wheels.
Old Dec 25, 2010 | 02:11 AM
calin's Avatar
calin
Really? You can't tell that an 18x11 -5 offset wheel won't fit up front without a lot of modification? The rear too for that matter.
Old Dec 25, 2010 | 08:06 AM
TehkMob's Avatar
TehkMob
OP, is your car lowered? if so on what and how low?
18x11 -5 isnt that agressive for a 18 wheel on a Z. You should be able to fit them with just a flat roll. Dont pull unless you plan on going more aggressive. If you are running that size in the front your definitely going to hafto take dem bishes to a wheel shop and have the back spacing shaved prolly to a +4 to run them. Im running a 19x11 +8 on the front and 19x11 et0 (spacer) on the rear. im running -2 camber out back to save tires and on a flat roll dont rub at all on a 275 35 19. on the front i been running a 245 or 255 35 19 with -4 deg camber with no issues accept for the a arm smacking the underside on the wheel well.
pic with above specs and flat roll rear only
Old Dec 25, 2010 | 08:53 AM
BoomerZ33's Avatar
BoomerZ33
this ish is bananas. can't wait to see these. i can understand putting that size on the rear but on the fronts too??
Old Dec 25, 2010 | 08:56 AM
240sxll's Avatar
240sxll
i will post the pics up as soon as i get my wheels back from the shop yeah i know i should have research but it was selling for 1300 dollars for 4 wheels. couldnt pass it up.
Old Dec 25, 2010 | 09:31 AM
gvulakh's Avatar
gvulakh
What wheels are these?
Old Dec 25, 2010 | 12:31 PM
mikex228's Avatar
mikex228
do you live in nola ?
Old Dec 25, 2010 | 12:54 PM
-miltdoggie-'s Avatar
-miltdoggie-
Roll, slight camber and some slight stretch....
Here are some pics of similar set ups I've had...
Old Dec 25, 2010 | 03:18 PM
TehkMob's Avatar
TehkMob
I love VS-KF's.... My wheels are advant garde M310
Replaced with Meister S1 for 2011
Old Dec 25, 2010 | 03:21 PM
TehkMob's Avatar
TehkMob
Thats a gravy *** deal, you were right for picking them up. Now just find a 10.5 outter barrel and call it good. you lose 7mm on the outs
Old Jan 5, 2011 | 07:03 PM
12 days and no photos. Very disappointed.
reno56
Interior
17
Nov 20, 2015 05:21 PM
davidm350
Oct 31, 2015 02:28 PM
nissan1310
Oct 12, 2015 08:54 AM
Shane86
Sep 17, 2015 05:33 PM
RyansZ33
Sep 15, 2015 05:54 AM
