Need help with my setup !! for speed pumps in Kuwait
Old Jan 4, 2011 | 11:36 PM
BlackFaytZ's Avatar
BlackFaytZ
Roberuta Cup Kit. Done.
Old Jan 5, 2011 | 01:06 AM
350z-900whp's Avatar
350z-900whp
because of the grip R888 offers do u know a street tire that would work similar or close to R888
so if no for 305/45 .. would a 305/35 fit ?
i need them because of TT kit power (545whp) for extra grip no sideways if and when i race
note its hardly rain her in kuwait
Old Jan 5, 2011 | 01:10 AM
350z-900whp
looks doesn't really matter i need something that preform and would raise my car a little
Old Jan 5, 2011 | 06:10 AM
scotts300's Avatar
scotts300
305/35 would probably be ok. R888s aren't that sticky when they're not in operating temperature. A good street tire, like Kumho XS, Hankook R-S3, BS RE-11, Dunlop Star Spec, Kumho V710, or a MT ET Street Radial, etc., would probably be better. I used to run the BFG Drag Radial on the rear of my high HP machine and really liked them until I tried to take a very mild turn - on the highway - at speed.
Old Jan 5, 2011 | 06:14 AM
zerafian's Avatar
zerafian
damn that last one a stock z would barely make it over...Im thinkin it wouldnt actually make it.
Old Jan 5, 2011 | 06:25 AM
BlaQ350z's Avatar
BlaQ350z
I know how you feel, the speed bumps here are a killer (not to mention the potholes).
I stayed with stock suspension because i knew i wouldn't be able to go anywhere lowered.
I got 18" 255/40 F and 275/40 R Toyo T1R and its working great.
Here is how my car looks (Keep in mind it is still under construction)
Attached Thumbnails Need help with my setup !! for speed pumps in Kuwait-img00103-20110103-1555.jpg   Need help with my setup !! for speed pumps in Kuwait-img00100-20110103-1554.jpg   Need help with my setup !! for speed pumps in Kuwait-img00111-20110104-1546.jpg
Old Jan 5, 2011 | 06:42 AM
Bigchef66's Avatar
Bigchef66
Only way to go in my opinion, I did it and don't regret it at all, saves precious body work which adds up $$$ real fast
Old Jan 5, 2011 | 07:00 AM
why not use bigger or taller tires
This number effects speedometer reading, operation of VDC and handing characteristics. I recommend that you stay within plus or minus 3 percent of the circumference.
Old Jan 5, 2011 | 09:14 AM
Gsedan35's Avatar
Gsedan35
hi guys,
first of all i just recived my car from US ..(now in kuwait). my car is lowered with JIC coil-over A2 flat about 1.5 inch lower than stock 350z and i have been told that the highest setting for this coil-over.
You were "told" your Jics are set to their highest. Have you verifed this by you turning a wrench yourself? Reason I ask, most coilover system's for the Z do not force you into that much of a drop.
IMO in the end I would go with another coilover system, if it was my car I would have pulled the Jics off the car the moment I got home with it, not a product I would own, even if they were free, they'd still get pulled.
Old Jan 5, 2011 | 07:40 PM
350z-900whp
honestly i haven't looked at them my self at that time but now am trying to find a shop with the tools ( hook i lost it ) to try to lift the car up if possible. going to check on them and let u guys know
Old Jan 5, 2011 | 07:44 PM
350z-900whp
so is this the spec of 350z or just an example. how to meager it ?
thanks for u input
Old Jan 5, 2011 | 07:52 PM
350z-900whp
u have a great looking car
with u setup do u have a problem with normal speed bump in terms of scrape
thanks for u input
Yes. This is the rear OEM tire.
Old Jan 5, 2011 | 09:32 PM
BlaQ350z's Avatar
BlaQ350z
When stock i was still scraping but the speed bumps we have are random sizes/shapes. If you know how to approach and where to go you can avoid some.
Old Jan 6, 2011 | 12:38 PM
bmccann101's Avatar
bmccann101
i have to jump in, as you have all been ridiculously helpful so far, almost uncharacteristicly so..
Its a BUMP, not a pump.
Speed bump.
speed pumps are what you pull with an ugly chunky butt girl.. and then run away in shame.
I now retreat to my desk to actually work again..
Old Jan 6, 2011 | 01:09 PM
vex008's Avatar
vex008
was thinking the same exact thing.
Old Jan 6, 2011 | 02:31 PM
str8dum1's Avatar
str8dum1
ya, there's no way that -1.5" is the highest ride setting. You should be able to put the ride height back at stock, which is 100% what I would do with all those bumps.
Also like someone else mentioned, the resonators are probably whats banging as well. Get them cut out if you dont wanna raise too much.
Old Jan 7, 2011 | 12:41 AM
  #38
350z-900whp
i will see what can i do with the coil overs (if can be raised or not ) this sunday and let u guys know.
Old Jan 7, 2011 | 12:48 AM
  #39
350z-900whp
Speed bump.
thanks for notifying me every thing got fixed , we are all her to help each other and in the end we are her to learn from each other
Old Jan 7, 2011 | 03:17 PM
  #40
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
As others have said already, the Roberuta Cup Kit is a viable option if raising the car cannot occur.
