Rear end steps out all the time ???
Old Jan 13, 2011 | 05:51 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Originally Posted by Z1 Performance
it could be any number of things - alignment would be the first place to check
THIS...
Old Jan 13, 2011 | 06:12 AM
nismo_nate's Avatar
nismo_nate
same thing happens to me.
i have to replace bushings and get a aliment done
Old Jan 13, 2011 | 06:51 AM
scotts300's Avatar
scotts300
Slow in, fast out. Check rear toe and the amount of steering input you are giving. The car will rotate (step out) if you let off the throttle mid-turn, as all the weight transitions to the front and allows the rear to get light. This is not good (unless done on purpose).
Old Jan 13, 2011 | 09:24 AM
Arvin89's Avatar
Arvin89
I have that, but only when i take a turn hard( not hard enough for the rear end to actually kick out or engage VDC), my tires are stretched so i heard thats part of the problem.
My wheels were also out of alignment, so i got that fixed and it did help. But i do still get it when taking a turn hard (assuming because of the tires).
Old Jan 13, 2011 | 10:20 AM
scotts300's Avatar
scotts300
What size front and rear tires?
Old Jan 13, 2011 | 12:45 PM
Barnabas's Avatar
Barnabas
National Z Club President
I had the same problem your describing and it ended up being my toe out of spec. Be sure to get print outs of your alignment specs.
Old Jan 13, 2011 | 03:08 PM
03Brickyard350z's Avatar
03Brickyard350z
Thanks for the help guys, I am thinking its a combination of my shocks being gone in the back, and the alignment cause taking this thing on an even ground free way...i get a hard pull to the right. So Tokico HP Blues and Tein S.Techs going in in two weeks and alignment two weeks after, will post all the alignment specs after that (hopefully I'll be able to get into spec with a very mild .6" drop)
Old Jan 13, 2011 | 03:09 PM
03Brickyard350z
Also, some people mentioned bushings...which ones would these be? As in which ones would I check to see if they are ok...any help would be great
Old Jan 13, 2011 | 03:59 PM
Barnabas's Avatar
Barnabas
for sure the big one in the center of your rear look right above the diff. This on is a common issue on our cars.
you can get the full solid rear bushings kit from SPL and do the 3 that are back there. SPL has very quality stuff and works great and lasts!
Old Jan 17, 2011 | 06:24 PM
stinky350z's Avatar
stinky350z
alignment i think
Old Jan 18, 2011 | 07:14 AM
y0shi's Avatar
y0shi
alignment... check the toe.
Old Jan 19, 2011 | 02:27 PM
03Brickyard350z
Ok so figured out that the rear diff bushing is completely blown, and by the looks of may have been that way for quite some time. Anyways, did a quick search and found that SPL and some other ppl make some solid bushings, so far found this on ebay, can anyone tell me if its worth it, or should I pay double (which i am not really wanting to do, for SPL brand name).
http://cgi.ebay.com/ebaymotors/PRO-S...Q5fAccessories
Thanks guys...
Old Jan 20, 2011 | 06:55 AM
stinky350z's Avatar
stinky350z
mine was doing the same , it was the toe being off
Old Jan 20, 2011 | 07:54 AM
Zazz93's Avatar
Zazz93
http://cgi.ebay.com/ebaymotors/PRO-SOLID-DIFFERENTIAL-BUSHINGS-SET-NISSAN-350Z-_W0QQcmdZViewItemQQhashZitem563dc532bfQQitemZ370403521215QQp tZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Thanks guys...
Solid aluminum is solid aluminum, the only thing to worry about is fitment, but that's pretty much everything on this part.
m_0g
Jun 3, 2021 10:05 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
FromGtoZ
Sep 20, 2015 03:41 PM
Mw870
Sep 10, 2015 07:50 PM
