Want a more aggressive wheel setup (recommendations please)
Old Jan 18, 2011 | 06:09 PM
terrasmak's Avatar
Originally Posted by fabre80
Sorry to bud in on your thread but I had a question guys. I have Axxis wheels also but mine are 19x8.5 front and 19x9.5 in the back, I currently have 235 35 on the front and I will be getting some new tires in the rear but wanted some meaty tires in the back. Can I put 285/30 or should I stay 275/35 ???
You can do 275/35, but if you had the proper front tires, 245 or 255's you could get away with 285/35's.
Originally Posted by al@phatrides
I find that my alignment doesn't do much for tire wear, my right foot seems to have the most influence in how fast my tires wear...
Same here.
Old Jan 18, 2011 | 07:55 PM
marques1's Avatar
marques1
Thanks everyone for your replies.
Old Jan 19, 2011 | 10:54 AM
reverse's Avatar
reverse
225/35 + 15 mm spacer front & 245/35 20mm spacer rear would be fine. doesn't look like your low enough to worry about pulling fenders & making huge camber changes. the smaller tires would compensate for clearance. i don't think you will have a major rubbing issue. probably about the same due to spacers. big bumps or sharp turns....
Old Jan 19, 2011 | 02:50 PM
SQBassHead's Avatar
SQBassHead
marques1:
i thought you stated that you dont want to change tire sizes anytime soon...
and alot of the advice given will cause you to have the Stretch and poke look (fyi, not bashing it, i like it, but to each his own)..... do you want that type of look????
you have to ask yourself that first... bc personally if i was going to get new tires, i would reccomend what i have, 255/30/20 F and 305/25/20 R ..... or you can also go with 245/30 in the front to have smaller diameter....
UP to you bro, but by any chance DO YOU KNOW WHAT CAMBER YOUR @ NOW??????
you should try and go measure how much you want to go out with a ruler, if you dont want to get new tires.... i think you should just measure it and later if you want diff. spacers then just sell the ones you have and go bigger, or sell the front spacers and put the rear spacers on the front ...
sorry for the rant, but What look do YOU want?
Old Jan 19, 2011 | 05:30 PM
fabre80's Avatar
fabre80
Same here.
what about spacers??? what can i do regarding that. I used to have 245 in the front but i like the 235 better for some reason. So, i will get 275/35 in the rear and i also wanted to add the spacers what to recommend?
Old Jan 19, 2011 | 08:24 PM
terrasmak's Avatar
Couldn' tell you, don't know the offsets of the wheels you own. If they are some crappy ADR's or other junk, they probably have the universal offset of +35. Then you just do a 20 or 25mm spacer front and rear.
Old Jan 20, 2011 | 07:45 PM
fabre80's Avatar
fabre80
They are decent wheels to me,lol, Axxis super hiro 19x8.5 front and 19 x 9.5 rear.
