Discount Tire?
Old Jan 26, 2011 | 03:01 PM
karimx93's Avatar
karimx93
Default Discount Tire?
Went to DISCOUNT TIRE to get some wheels
and they said for 19x10 285/-/19 i need an offset of +32-35
but i have read many forums saying +22offset for rims that are 19x10
whos right?
and is there rubbing with 22 offset
Old Jan 26, 2011 | 03:07 PM
angelo350z's Avatar
angelo350z
whos right?
Ok, so they're saying that 19x10 wheels with 285/?/19 tires need to have an offset of +32-+35 to fit a 350Z? If so, they are wrong. People have used wider wheels with more agressive offsets. (19x10.5, 19x11, +17, +12, etc).
Old Jan 26, 2011 | 03:12 PM
karimx93's Avatar
karimx93
yea i wanted to order the 19x10 with +22 offset but they said it would cause ABS and TRACTION CONTROLE issues? also it would rub on the fenders?
Old Jan 26, 2011 | 03:15 PM
Waiz's Avatar
Waiz
Search the fat tire thread.
Discount tire is just being conservative but they are correct.
Old Jan 26, 2011 | 03:25 PM
angelo350z's Avatar
angelo350z
Talking
I ordered 19x10.5 +22 wheels with 285/35/19 for the rear of my car and all I would need is a mild fender roll. If our wheels are similar in construction and design (TE37 for me), then your wheels would theoretically be sunk in around 12mm more than mine (since your wheels are half an inch skinnier) with your tires sticking out roughly about the same way (since both are 285s). This means you probably will need a slight fender roll. It will fit, but a slight roll might be necessary considering different tires have different actual widths.
Old Jan 26, 2011 | 04:09 PM
juju's Avatar
juju
This belongs in Wheels/Tires and doesn't require two threads.
+1 on Discount Tire giving a conservative recommendation
Old Jan 26, 2011 | 04:23 PM
karimx93's Avatar
karimx93
i thought I did and idk why it posted it twice definitely not intended either way i doubt it will bring the end of the world
Old Jan 26, 2011 | 05:16 PM
terrasmak's Avatar
+1 , and i would look into 10 to 10.5 rears. you may not find nice wheels at Discount.
Old Jan 26, 2011 | 05:24 PM
zerostyle's Avatar
zerostyle
i work at discount tire and i +2 the guy being conservative. our fitment charts are on the computers are conservative and arent meant to give people "aggresive" fitments.
Old Jan 26, 2011 | 05:25 PM
zerostyle's Avatar
zerostyle
just because the wheels arent on the site doesnt mean we cant get em...you give us a wheel and we can more than likely get it...
Old Jan 26, 2011 | 09:19 PM
karimx93's Avatar
karimx93
thanks, the guy that worked for some reason was trying so hard to steer me away from the getting the wheels with +22 offset, but i will get them anyway with 285/35/19...since this is your profession you think if i go 18x8 245/40/18 in the front would ruin some performance(handling)?
Old Jan 26, 2011 | 09:51 PM
OkashiZ's Avatar
OkashiZ
it'll fit.. I have 19x10.5 295/30/19 in the rear with a +22. its doable. roll the fenders though.
Old Jan 26, 2011 | 11:45 PM
terrasmak's Avatar
YOu mean, understeer like a pig? Yes , run either a 255/40 front or 265/35
ablaine
Nov 29, 2016 10:13 AM
