need your opinion re wheels
Old Jan 31, 2011 | 05:33 AM
autosportz's Avatar
autosportz
Default need your opinion re wheels
hello all, i'm in the process of a custom wide body design (not a flare kit) for my 03 350z. i would like to make a decision on wheels and tires and here is where i need your help.
i would like to fill the rear wheel well with more tire, as such i need to know what the ideal 19" wheel/tire set-up would be. my wide body design will extend out approximately 2-3" inches on each side in the rear and 1-2" in the front.
i can remove or cut away any part of the fender lip if necessary.
i don't want issues with tire rubbing, wheel/brake issues etc.
i don't mind using a high-end spacer of approximately 1-2" if required.
will a set of tsw kyalami (hypersilver) wheels 19X8... 40 offset front and 19X9.5... 20 offset rear allow for a wide enough tire to achieve my objective? if not why and what would you recommend?
thanks for your help on this,
regards,
autosportZ
Old Jan 31, 2011 | 05:35 AM
ZS14RR's Avatar
ZS14RR
Hell no.
You are way off.
Old Jan 31, 2011 | 07:04 AM
terrasmak's Avatar
19x9.5 for a widebody, is that going to be your spare?
Old Jan 31, 2011 | 07:11 AM
zerafian's Avatar
zerafian
sounds like youv got some money to spend if your going to take on this project....Im sure you can afford some good rims to go with it.
make them 19/11 -25 front and 19/13 -50 rear and your good to go if your actually going that much wider.
Old Jan 31, 2011 | 08:01 AM
D&G35's Avatar
D&G35
"Search" button is your friend....there are a few guys on the forums that have the widebody...the specs u're looking at aren't even close...those aren't even enough for a sedan fitment let alone a Z...search sum more..u will find your answers
autosportz's Avatar
autosportz
thank you for your input regarding the wheel sizes. i looked at the photos of your wide body project... nice work! i am planning an entirely new design including wide body look using polyurethane foam.
design knowledge i have, mechanical expertise i do not, this is more of a design project... if it works the performance part of it comes later.
i assume your suggested set-up deletes the spacer from the equation?
with your suggested wheel set-up what tire sizes would you recommend?
how much farther from the lip will your tire suggestion extend?
will this require any cutting off of the fender or lip to achieve an aggressive set-up without tire rubbing?
thanks again for the help, i appreciate the knowledge and suggestions the members can offer me.
regards,
autosportZ
Old Jan 31, 2011 | 08:56 AM
exZilaration's Avatar
exZilaration
Wheels are way too skinny and That offset is horrible man
You gotta go with like 19x10 19x11 or wider bro!
Old Jan 31, 2011 | 09:27 AM
Wheels are too skinny. You will never be super flush.
Old Jan 31, 2011 | 03:08 PM
ZS14RR's Avatar
ZS14RR
If you are gonna design something execute it right ****.
Old Feb 1, 2011 | 07:57 AM
scotts300's Avatar
scotts300
Need to know if the offset is + or -. Those look like conservative wheels withOUT the widebody.
Old Feb 1, 2011 | 11:24 AM
autosportz's Avatar
autosportz
not quite sure i understand the meaning of your message, however, you won't recognize the car as a 350Z when it's completed and you can be sure it will be executed properly... ****?
Old Feb 1, 2011 | 11:42 AM
Done Deal DR's Avatar
Done Deal DR
Agreed. Putting TSW's on a widebody is total fail regardless of width and offset though.
Obadabot
Jun 18, 2023 11:31 PM
