235/30/20 front & 295/30/20 rear????
Old Feb 9, 2011 | 07:11 AM
ronsupercars's Avatar
ronsupercars
Default 235/30/20 front & 295/30/20 rear????
Thinking of something different.
I'm currently running 245 & 285/20's. I love the stance of the 997 Turbo and would like to know if these sizes will work for our cars.
LOVE IT!!!!!!
Old Feb 9, 2011 | 07:20 AM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
That's a lot of stagger. If your car has VDC/TCS that will be too much and cause problems.
Old Feb 9, 2011 | 07:23 AM
phreaktor's Avatar
phreaktor
Design Engineer
I'm running 245/35/19 and 295/30/19 with 0 issues with TCS. 15mm spacers up front.
Old Feb 9, 2011 | 08:45 AM
Are you going to talk about it or are you going to do it?
Old Feb 9, 2011 | 09:14 AM
DavesZ#3's Avatar
DavesZ#3
The stagger on your setup is 0.2" which is actually at the low end of the acceptable range. OP is talking about a setup with 1.4" of stagger, that's way higher than the recommended 1" max. You've got a 35/30 mix of profiles, he doesn't.
Old Feb 9, 2011 | 06:36 PM
ronsupercars
David. I'm asking cause I'm interested. I do need to replce my fronts so now's the time.
Old Feb 9, 2011 | 07:26 PM
Difference in circumference is 5.5 percent. VDC will not like this.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
