Bridgestone Potenza RE-11's -- what size?
Old Feb 14, 2011 | 06:44 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
Default Bridgestone Potenza RE-11's -- what size?
Hey guys,
Could use some help on what size tires to go with.
My car is a DD with TT. Planning on getting some 18" wheels (wider also) down the road to have more options for rubber. For now Im going to stick with my 19" wheels.
front: 19 x 8.5 + 21 offset
rear: 19 x 9.5 + 23 offset
I reviewed the spec sheet for the RE-11's on Tire Rack.
I am considering going with the following:
255/35/19
275/30/19
Would those work ok with my wheels? Need to roll?
Problems with traction control, etc?
Any thoughts or comments are appreciated.
Thanks!
Old Feb 14, 2011 | 07:54 AM
terrasmak's Avatar
285/35-19 rear tire will work for you, the combo you listed will have problems.
Old Feb 14, 2011 | 07:57 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
OK Thanks
So I could go with:
255/35/19
285/35/19
Any other thoughts?
Old Feb 14, 2011 | 08:02 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
Wouldnt the 285 be a bit wide for my wheel which is 9.5" ??
Old Feb 14, 2011 | 08:06 AM
terrasmak's Avatar
Its a stiff sidewall tire, will be fine. Seen it done many times on cars that people bought narrow wheels.
Old Feb 14, 2011 | 08:39 AM
nismo1543freak's Avatar
nismo1543freak
You can go with 285/40/19 instead of the 35 to give a better ride since the tire is a little bit taller. More comfort IMO
Old Feb 14, 2011 | 09:01 AM
VQ35deMax's Avatar
VQ35deMax
Out of curiosity why are you set on the Re-11? Save some money and get the Dunlop Direzza Sport Z1 Star Spec imo
Old Feb 14, 2011 | 09:38 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
I dont see that as an option for this tire. I checked Tire Rack's specs and also Bridgestone website specs. Does not seem to exist.
Old Feb 14, 2011 | 09:39 AM
67ZNISMO's Avatar
67ZNISMO
star specs would be good but it doesn't come in 19's. I think the largest it goes is 275/35/18
Old Feb 14, 2011 | 09:41 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
I am running 19" wheels. As far as I can tell, this tire is not offered in 19". Only up to 18".
I checked Tire Rack's website and the Dunlop website.
Am I missing something here??
Old Feb 14, 2011 | 09:42 AM
Voboy's Avatar
Voboy
way too tall.
Old Feb 14, 2011 | 09:43 AM
67ZNISMO's Avatar
67ZNISMO
nope, you're not missing anything. Stick with your choice of RE-11's....IMO if you're boosted - sticky tires is a must
Old Feb 14, 2011 | 09:49 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
Thanks. That's the plan. Currently running T1-R 245/35/19 and 275/35/19 and they just dont have the grip I need. Can break em loose in 3rd gear.
So I will stick with RE-11's
255/35/19
285/35/19
No issues with VDC or TCS or tire height or anything.....right?
Old Feb 14, 2011 | 09:51 AM
TheFarmer's Avatar
TheFarmer
Should be fine.
Old Feb 14, 2011 | 09:58 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
Thanks to all for the help.
One thing that bothers me is that the rear sizes are not listed on the Bridgestone website spec sheet but they are listed on Tire Rack and when I place the order it says "in stock".
Old Feb 14, 2011 | 10:00 AM
terrasmak's Avatar
255/35/19
285/35/19
no issue at all.
Old Feb 14, 2011 | 10:07 AM
Thumbs up
255/35/19
285/35/19
Speedometer and VDC are on the money. All systems are GO.
Old Feb 14, 2011 | 01:33 PM
DRIFT's Avatar
DRIFT
All LASER LASIK
Order placed through Tire Rack.....shipment on the way.
Thanks again everyone!
Old Feb 14, 2011 | 02:09 PM
rcdash's Avatar
rcdash
If that doesn't work, only street tire stickier, if you can stand the treadwear and noise, is the R888. I ran those last year. Now RE-11 and hoping that warm temps will bring some traction.
Old Feb 14, 2011 | 04:33 PM
DRIFT's Avatar
DRIFT
All LASER LASIK
I would love to run the R-888 but they don't have the right sizes for my wheels. Someday I will make the Z my weekend car and then I'll run 18's with the R-888. For now I'm really looking to see how these RE-11's perform compared to my current T1R's.
I've heard good things about them.
