19x9.5 +40 Axis Matrix
Old Feb 23, 2011 | 09:55 PM
Fito68's Avatar
Fito68
Default 19x9.5 +40 Axis Matrix
Hey guys I got a fitment question for these size wheels. I am trying to get these all around and not quite sure what tire size to get to ensure they fit with no rubbing. Anyone who has had a set of these or knows about fitment please reply
Old Feb 24, 2011 | 03:23 AM
08panna's Avatar
08panna
9.5" +40 will be a horrible fitment. youll need big time spacers. but some axis's with a much lower offset
Old Feb 24, 2011 | 07:02 AM
The possible combinations for 9.5 inch wheels is staggering. You can run anywhere from 245 to 275 mm tires.
Old Feb 24, 2011 | 07:39 AM
reverse's Avatar
reverse
Doesn't matter what tire size. They wouldn't rub anyway with that offset. 245 to 275looks to be about right.
Old Feb 24, 2011 | 10:22 AM
derekinthez's Avatar
derekinthez
you need better offsets for the z
Old Feb 24, 2011 | 10:50 AM
Fito68's Avatar
Fito68
is 15-30 good?
Old Feb 24, 2011 | 06:31 PM
kemps's Avatar
kemps
0 to 15
Old Feb 24, 2011 | 10:14 PM
terrasmak's Avatar
9.5 +40 up front should touch the splindle. +35 only has 2 to 3mm of clearance.
9.5 front you want inbetween 15 and 30 depending on your goals and taste. Then between 0 and 20 for the rear.
Old Mar 4, 2011 | 02:11 PM
Originally Posted by Fito68
is 15-30 good?
You have been a member for 3 years and are NOT using a offset calculator? Shame on you.
Old Mar 4, 2011 | 02:39 PM
ZS14RR's Avatar
ZS14RR
I'm amazed sometimes..
35reilly
Sep 28, 2015 07:42 AM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
