Q: Rota Torque 18.5 tires sizes
Old Mar 25, 2011 | 07:51 PM
langtubip's Avatar
langtubip
not fast enuff
Default Q: Rota Torque 18x9.5 tires sizes
Got a set of rota torque 18x9.5 all around +28 offset. currently i'm running 245/45/18 tires and 15mm spacers front, 25mm spacer rear lowered with tein s-tech. looking for new tires and don't know what size to go with. what would be good tire sizes?
Old Mar 25, 2011 | 08:04 PM
You have a wheel with a 18.5 inch diameter? Really?
Old Mar 26, 2011 | 04:56 AM
quinnry2's Avatar
quinnry2
im guessing you mean 9.5-
I have 265/35 front 285/35 rear and like the way they look.
Old Mar 26, 2011 | 01:13 PM
langtubip's Avatar
langtubip
not fast enuff
Oops yeah 18x9.5 ^^^ r u lowered? I was thinking 265/35 and 295/35. Is it gonna rub?
Old Mar 26, 2011 | 01:17 PM
JPsZ's Avatar
JPsZ
295 rear with a +3 offset will rub. You should probably run a smaller spacer in the rear, cause even a 275 will rub with that spacer.
Old Mar 26, 2011 | 04:38 PM
ZS14RR's Avatar
ZS14RR
Smaller spacer to put on a bigger tire.
Old Mar 26, 2011 | 04:53 PM
quinnry2's Avatar
quinnry2
My offset is +20 with a 10mm spacer in the rear. I have a slight roll in the back and think I would have to raise the car or ditch the spacer if I had a 295.
here is a pic of the space to make your own judgement if you would like.
Old Mar 26, 2011 | 06:47 PM
langtubip's Avatar
langtubip
not fast enuff
If I'm doing +13 offset and 295 tires, will that be ok no rub?
Old Mar 26, 2011 | 08:59 PM
terrasmak's Avatar
9.5 +15 can and will rub with 275/40 without a roll at stock height.
Old Mar 26, 2011 | 10:58 PM
JPsZ's Avatar
JPsZ
Even with no spacer, at +28 with a 295 tire depending on your camber, you'd probably need a fender roll.
Old Mar 27, 2011 | 06:37 AM
langtubip's Avatar
langtubip
not fast enuff
Getting fender rolled next week. So with my setup +3 offset i best go with smaller tire like 265/35/18?
Old Mar 27, 2011 | 02:50 PM
Nissan puts a 265 mm tire on a 10.0 wheel. And you want a 295 mm tire on a 9.5 inch wheel?
