Grinding vs. Rolling?
Old Dec 1, 2003 | 10:40 AM
ZZtopp's Avatar
ZZtopp
Default Grinding vs. Rolling?
At the Mackin Booth at SEMA, they had a 350Z with 10.5" LE37's on the rear. Instead of rolling the fenders, it appeared that they had ground down the inside fender lip to about 1/4." This seems like a logical alternative to rolling. Has anybody else done this?
Old Dec 1, 2003 | 12:15 PM
Topics II's Avatar
Topics II
I wouldnt recommend it because if there was ever contact with the fender, it will cut into the tire. If you roll the fenders you create a smooth edge. Its like a U shape, ya know, but flat so it will not cut into the tire.
Old Dec 1, 2003 | 12:45 PM
ares's Avatar
ares
Veteran
ive heard of it being cut away all together. the downside I saw was very limited structural strength. leaning on the fender might be enough to bend it. atleast with rolling you have a little off that structure left
Old Dec 1, 2003 | 01:36 PM
havabooz's Avatar
havabooz
i think its a better alternative because it prevents the possibolity of paint chipping that rolling the fender might cause
plus someone on this board has 10.5 +22 and had his fender rolled
but from the pic it looked like it wouldnt even be close to rubbing
in that same thread some guy said he had the same setup without rolling but im not so sure i believe him because he had like 20 posts and ive never seen pictures
anyhow..i think cutting away is not a bad idea....what about making a more negative camber...wouldnt that help too???
Old Dec 1, 2003 | 02:08 PM
Topics II's Avatar
Topics II
it all depends on what tire size you run as well. We had a set of 18x10.5 +15mm with 225/40's on the front and back of a z. No rub, no roll either. And lowered a pretty good bit, with around -1 degree camber in the rear, and whatever the stock went to with lowering the car.
Old Dec 1, 2003 | 02:23 PM
2003z's Avatar
2003z
I once did this to my first car, an 83 sentra, back in 1984. I drove the car for 3 years afterwards with no structural, rubbing or paint issues.
I taped off the outside of the fender with masking tape to avoid accidental damage, and used an air grinder with a flexible wheel, and just slowly worked at it til the factory lip was down to about 1/8". I was then able to run rwd offset wheels on the back and give the appearance of a stagger. Not bad for 20 years ago!
Attached Thumbnails Grinding vs. Rolling?-mike-golding-s-83-nissan-sentra.jpg
Old Dec 1, 2003 | 02:43 PM
ZZtopp's Avatar
ZZtopp
Could you describe that flexible wheel?
Old Dec 1, 2003 | 05:43 PM
BigTwin's Avatar
BigTwin
Dude that Sentra is pimpfukintastic.
Obadabot
Jun 18, 2023 11:31 PM
_koubie_
Sep 20, 2015 06:34 PM
