Wheels & Tires Wheels, Tires, Big Brakes, Coilovers, etc...
Toyo R888, R1R and RA1 Clearance Specials
Old Apr 14, 2011 | 09:47 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Default Toyo R888, R1R and RA1 Clearance Specials
While we offer the full range, the sizes shown are in stock in limited quantities, and ready for pickup or delivery. You will not see pricing like this again, and it's first come, first served only, so don't miss out!
Toyo R1R -
An aggressive, arrowhead tread design, extra wide footprint, high-grip compound, and advanced autocross-inspired casing design, provide every advantage while driving hard through the corners and quickly accelerating in the straight-aways. It's extreme performance for serious street driving.
•Silica reinforced high-grip compound.
•Stability control slits maintain the block stiffness during aggressive braking.
•Tapered center block edge increases center block stiffness.
•Unidirectional arrowhead shaped pattern enables excellent water drainage.
•Tapered center block edge increases hydroplaning resistance.
•Silica reinforced high-grip tread compound increases wet grip.
•Advanced autocross-inspired casing design with modified radial construction increases casing stiffness to give crisper handling.
•Multi-width EVAC channels improves water dispersion and contributes to improved steering response by narrowing towards the tire edge to widen the shoulder block area.
•Jointless bead wire.
•Wide high-tensile steel belts.
•High steel side-ply (select sizes).
•T-Mode Design Technology.
•Spiral wound cap ply.
•Computer optimized low profile design
225-50-16 - $569 shipped for the set of 4!!!!
235-40-17 - $589 shipped for the set of 4!!!!
245-40-17 - $730 shipped for the set of 4!!!!
255-40-17 -$745 shipped for the set of 4!!!!
245-40-18 - $799 shipped for the set of 4!!!!
255-35-18 - $864 shipped for the set of 4!!!!
Toyo RA-1
The performance-proven RA1 features all the high-tech components to provide an uncommon advantage to the cost-conscious competitor who still demands quick lap time. It's true performance from Toyo!
The RA1 has a soft but durable tread compound and stepped tread design. This was the tire formerly used in the Speed World Challenge as the standardized tire.
•Advanced race-proven casing design.
•Two steel belts.
•Heavy-duty bead construction.
•Tread depth can be shaved to maximize dry traction response.
•Full tread depth of 8/32nds provides aggressive wet traction
205-40-17 - $920 shipped for the set of 4!!!!
275-35-18 - $1920 shipped for the set of 4!!!!
305-35-18 - $1920 shipped for the set of 4!!!!
335-30-18 - $1920 shipped for the set of 4!!!!
Toyo R888 -
Ideal for road racing, track days and high performance driving schools, the Proxes R888 is the next-generation, street legal competition tire from Toyo Tires. In competition the R888's improvements in casing and tread design improve dry performance while maintaining wet traction and control.
Features:
Enhanced R-Compound Tread - Maximizes grip for better competitive handling and performance.
Unidirectional V-Shaped Tread Design - Increased tread area and limited void improves dry traction V-shaped grooves assist with wet traction.
Continuous Center Contact - Increases braking performance and dry traction.
Semi-Slick Shoulder Area - Improves grip for better steering response.
Stiff Bead Construction And Wider Tread Width - Increases cornering force for better competitive handling.
195-55-15 - $620 shipped for the set of 4!!!!
205-40-17 - $894 shipped for the set of 4!!!!
215-45-17 - $899 shipped for the set of 4!!!!
335-30-18 - $1488 shipped for the set of 4!!!!
295-30-19 - $1488 shipped for the set of 4!!!!
if you know any Porsche owners, we also have a deal on the 225/40/18 front and 285/30/18 rear
to order just give us a call!
Old Apr 19, 2011 | 09:23 AM
Z1 Performance
Former Sponsor
ttt!
Old Apr 19, 2011 | 12:00 PM
nightcrawler_8's Avatar
nightcrawler_8
Hi, I want the following size
295/30/19 for rear
265 or 255/30/19 for the front
R888 or R1R
Pm me please
Old Apr 19, 2011 | 12:24 PM
Z1 Performance
Former Sponsor
the tires available are all posted with prices - we're clearing out some inventory that we got a special deal on and this is what is left
Old Apr 26, 2011 | 11:06 AM
Z1 Performance
Former Sponsor
ttt!!!
Old Apr 27, 2011 | 06:09 AM
350ZMPH's Avatar
350ZMPH
quote...
R888
275 or 295/30/19
265/30/19
nevermind ...
Old Apr 27, 2011 | 10:36 AM
Z1 Performance
Former Sponsor
everything available, in stock, is posted
any other combos, best bet is to call with your specific request to check price and availability
Old Apr 29, 2011 | 07:48 AM
fast300z's Avatar
fast300z
Do we have to buy 4? I am interesting in the 295/30/19 but only want 2. I am ready to buy now. If you have the 305/30/19 I would be interested in those as well.
Old May 2, 2011 | 10:13 AM
Z1 Performance
Former Sponsor
Posted price is based on 4, but we can do 2 as well, at a bit more per piece. Just give us a call
295/30/19 and 305/30/19 are both available
Old May 9, 2011 | 01:18 PM
Z1 Performance
Former Sponsor
ttt for Monday!
Old May 26, 2011 | 07:34 AM
Z1 Performance
Former Sponsor
up top!!
Old Jun 2, 2011 | 08:35 AM
Z1 Performance
Former Sponsor
up top
416blueZ
Jun 11, 2024 10:56 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
