Wheel spacers and tire size on new rims
Old Apr 25, 2011 | 02:23 PM
Peaknismoz's Avatar
Peaknismoz
Default Wheel spacers and tire size on new rims
Hi everyone, first off I have a 2003 350z Touring with stock wheels and tires size 225/45/18 front and 245/45/18 rears. 45mm offset all around
I just bought some new rims Rota DPT 18x9.5 front and 18x10 rears. 35mm offset all around.
I want to put the stock tire 225/45/18 and 245/45/18 on my new rims. Is it possible and is it gunna be a stretch and if so, is it ok?
second, I want to get some spacer to make it a lil more flush then usual. What spacer should I go with, I know 10mm spacer will get my wheels back to stock offset specs so should I run 20mm and 25mm in the rears will that cause any rubbing?
Please take the time to help me with these question and all advice and help appreciated. Thank you
Old Apr 25, 2011 | 03:29 PM
terrasmak's Avatar
http://www.1010tires.com/wheeloffsetcalculator.asp stock specs are 18x8 +30, now just figure out how much further you want them to stick out.
Hint with the tires you want to run "large spacer"
Old Apr 25, 2011 | 04:17 PM
sdZ33's Avatar
sdZ33
I will let you figure this out on your own... Terra got you off to a GREAT start...
Old Apr 25, 2011 | 05:30 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
After getting your tires, you can choose spacer by:
1) Mount tires & get alignment sans spacer
2) Use a metric ruler or caliper to measure from the face of the top of the tire out to where you want it to be in comparison to the lip/fender
3) Determine if you need to roll fender to get the look that you want
Buy spacer based off of your measurement, because a calculator is only going to be so accurate when your drop, alignment & personal preference can make a difference.
Old Apr 25, 2011 | 05:42 PM
For wheel-tire width see: http://www.tiresandco.ca/equivalency-tables-advice.html
Old Apr 25, 2011 | 06:29 PM
Peaknismoz's Avatar
Peaknismoz
So any suggestion on which spacer and according to the tire width link I cant run 225/35/18 on 9.5inch rims?
Old Apr 26, 2011 | 01:36 PM
Peaknismoz's Avatar
Peaknismoz
I was thinking running 245/40/18 front and 275/40/18 rears
Anyone think thatll be good on stock springs? And do you think 40 offset on the tires is good for 35mm offset on my new wheels?
Old Apr 26, 2011 | 01:48 PM
275/40/18 : Actual speed 100.0 MPH. Speedometer will read 100.07 MPH. Cant get much better than that.
Old Apr 26, 2011 | 05:06 PM
terrasmak's Avatar
255/40 front will also work great, stock height or lowered those the a set of the proper tires for the car.
A very common wheel combo is 18x9.5 +15 front and 18x10.5 +15 rear, use the link i posted and work the numbers a little to figure out what specers you will want.
JjL
East Canada
Jun 12, 2019 03:04 AM
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
PLAYDIRTY
Oct 12, 2015 07:45 AM
