Difference between painting and powdercoating?
Old Jun 17, 2011 | 03:03 PM
BYBYCOP's Avatar
BYBYCOP
Default Difference between painting and powdercoating?
Is there a difference between painting wheels and powdercoating wheels?
If so, is one cheaper, better, etc. Than the other?
Old Jun 17, 2011 | 03:23 PM
Yes there is a technical difference but the technique should not concern you. A professional wheel painter will choose a technique to give you the results that you want. Don't get caught up in the language.
Old Jun 17, 2011 | 08:06 PM
moforeynolds's Avatar
moforeynolds
Paint is likely going to be cheaper than powdercoating. It will chip easier, but it's ability to withstand regular driving will depend on the quality of the finish. Powdercoating is generally more expensive, but the finish is spectacular. If you are wanting to powdercoat a forged wheel though, it's a must that you go to a shop that is familiar with powdercoating forged parts to maintain the integrity of the part.
Powdercoat all the way for me.
Old Jun 17, 2011 | 09:03 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
it depends on what you want to get coated
Old Jun 19, 2011 | 12:17 PM
BYBYCOP's Avatar
BYBYCOP
Okay, I called the shop that does it here in NOVA and they quoted me $138 per wheel for powdercoating. Does that sound like a fair price? I'm assuming they base the price off of the wheel size.
Old Jun 19, 2011 | 01:54 PM
Duckeee's Avatar
Duckeee
that's an okay price but i'd call around a few places for more. just google powder coating in chantilly or whatever and there may be info on other forums as to where to go.
Old Jun 19, 2011 | 09:09 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Powdercoating is a self-limiting coating process so it typically results in a uniform coating when done properly. That is, areas don't get undercoated or overcoated.
This can be done with paint but takes a lot more skill particularly when painting complex shapes like wheels.
You can apply all kinds of coatings using the powdercoat method. It's also called electrostatic spray technique.
Both can be done well or poorly, sometimes only time will tell. If it's important to you I would say don't ever go cheap on paint.
Old Jun 20, 2011 | 05:49 AM
JMS71585's Avatar
JMS71585
Interesting information. i was unclear of the difference myself. ^ Thanks for the clarity.
Old Jun 20, 2011 | 08:15 AM
Chebosto's Avatar
Chebosto
don't forget that when powdercoating, the electrostatic spray particals are applied to an object that is then uniformily heated at a specific temperature... i.e. it's baked.
Old Jun 20, 2011 | 12:56 PM
BoomerZ33's Avatar
BoomerZ33
that's alot. i got my wheels professionally powdercoated for $100/wheel and turn around time was 2 days.
Old Jun 20, 2011 | 09:11 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I was going to mention, but they bake certain paints/clearcoats as well right?
Old Jun 21, 2011 | 07:12 AM
SA Z-boi's Avatar
SA Z-boi
I got my rims painted for 100. That was for all 4 wheels
Old Jun 21, 2011 | 09:11 AM
Chebosto's Avatar
Chebosto
i think they do cure them with heat, but nothing to the 3-4xx* F that PC does for the entire wheel....
if its a bad PC place, they'll bake the wheel too long.. which isnt good for integrity.
Old Jun 21, 2011 | 10:14 AM
BYBYCOP's Avatar
BYBYCOP
Yeah I'm going to shop around. I think that $100 a wheel is fair, that's what I thought it would be. Any of you guys from Northern Virginia and have your wheels painted or powdercoated? Any pics? I'd like to see the end result. Thanks for all of your help, much appreciated!
Old Jun 27, 2012 | 07:11 AM
IceIceIce's Avatar
IceIceIce
Default Thinking about powder coating
I want to powder coat my rims from black to white. Does anyone suggest this over painting? are there any negatives to powder coating?
If anyone could supply a picture of their wheels after they coated them or something that would be great! Thanks
Old Jun 27, 2012 | 07:31 AM
BoomerZ33's Avatar
BoomerZ33
i used to have white powdercoated wheels. a friend of mine who is a professional did the job for me. here is his site and he explains the benefits versus painting it.
http://needpowdercoating.wordpress.c...owder-coating/
my wheels had a glossy finish which made it easy to clean but since it was white it was hard to keep clean
Old Jun 27, 2012 | 07:46 AM
Sunset350ZR's Avatar
Sunset350ZR
I powdercoated mine due to mismatch of colors after I broke one in a blow out. So far I have seen no negatives to the process though I have heard that the heating process can make the wheels weaker.
Also my centercaps were plastic so now I have to decide something to do with those. I was happy with result. They are just regular grey until sunlight hits them and then the the sparkle jumps out. This picture is at nightin my garage and outside after install before a storm.
Sorry bout the size.
Old Jun 27, 2012 | 11:37 AM
thenoname's Avatar
thenoname
Default Powder coating
Hi ya
I got Abbey Motorsport to powdercoat my OEM Rays black.
fantastic job and as they are forged should not be effected by the heating
process.
There are a few horror stories this side of the pond about powder coating cheap
after market wheels.
Peter
Last edited by thenoname; Jun 27, 2012 at 11:40 AM. Reason: trying to uplaod pictures
Old Jun 27, 2012 | 11:44 AM
thenoname's Avatar
thenoname
Hopefully I have managed to uplaod some shots of the wheels or at least given you a like to them
Appologies if l have done this wrong (again)
http://i1124.photobucket.com/albums/...g/DSCF0261.jpg
http://i1124.photobucket.com/albums/...g/DSCF0255.jpg
Old Jun 27, 2012 | 02:38 PM
Waiz's Avatar
Waiz
Threads merged, please search before creating a new topic...
