wheels spacers...
Old Jun 24, 2011 | 09:10 PM
Bmurray350z's Avatar
Bmurray350z
Default wheels spacers...
is it smarter to run smaller in the front than in the rear? or same on both?
i wanted to go 25mm on all.. but ive seen some go 15mm on the front and 25mm on the rear..
whats best?
Old Jun 24, 2011 | 09:15 PM
omsin523's Avatar
omsin523
depends on your offset, and wheel width all of this comes into play.
Old Jun 24, 2011 | 11:09 PM
OkashiZ's Avatar
OkashiZ
Have you looked in the official wheel spacer thread?
Old Jun 24, 2011 | 11:14 PM
Mcutali's Avatar
Mcutali
Thumbs up re
whats best?
depends on your setup just like omsin said, for instance im on tein basic coilover kit, rear lowest setting still have collars.. front is low still another 1.5 in probably to go but not going to be doing that lol!, power to ya guys that do.- im running 25mm all around its very nice, 30 would be total flush.. but its all good man. 20mm up front might be better suited in my opinion, but 25 is flush up front - stock touring wheels from 04
Old Jun 25, 2011 | 12:04 AM
scotts300's Avatar
scotts300
What wheels? What size tires? What suspension?
Old Jun 25, 2011 | 05:27 AM
Bmurray350z
Wheels are Drag Dr-11 (17x7)
Tires are front: 225/50zr17
Rear: 235/50r17
stock suspension. dropping it an 1.0" in the front and 1.2 in the back whenever my tanabe springs come in. but everythig else is stock
Old Jun 25, 2011 | 06:28 AM
Toby-22's Avatar
Toby-22
you have 17x7 rims? civics run wider rims than you
Old Jun 25, 2011 | 06:30 AM
omsin523's Avatar
omsin523
Checking online I think your offset is +40 which is worse than stock.
Old Jun 25, 2011 | 06:32 AM
Bmurray350z
I'm hoping to upgrade to 19x9 soon though.
Old Jun 25, 2011 | 06:40 AM
omsin523's Avatar
omsin523
If you want to be flush its going to be hard with those wheels you will need like 30mm or more
Old Jun 25, 2011 | 06:42 AM
Bmurray350z
Well I definitely want it to be flush. What if I waited till I upgraded to 19x9. I'm going to be running F: 245 and R: 275
Old Jun 25, 2011 | 02:34 PM
dhays's Avatar
dhays
I'd wait until you get the wheels you want to run with. Then you can see what you want to do. It will make a difference what the offsets are on those 19x9 that you are looking at.
Here are two shots of my Z with the v.1 track wheels. They are 18x8 +30 front and 18x8.5 +33 rear. I have 20mm spacers front and 25mm spacers rear. Take a look at the offset of those new rims and add and subtract accordingly.
Old Jun 25, 2011 | 02:37 PM
Bmurray350z
yours looks pretty flush to me. but yeah, i'll probably end up waiting till i get my 19x9's. Its just theres so many more things i want to do to the Z, other than wheel spacers, lol
Old Jun 25, 2011 | 02:46 PM
dhays's Avatar
dhays
I understand. Spacers are a pretty silly thing to do for the most part anyway just to slightly change the look of the stance (but I did it anyway). When you do decide to look at them, I would suggest either buying a used set of Ichiba V2 spacers, or do what I did and get a set from an ebay company called "optionsselect". I've been very happy with them for DD.
Disclaimer, I take off the spacers when I put on my wheels for AutoX
