HELP: Tires Size, 19 x 9.5 +20 offset ? ? ?
Old Jun 26, 2011 | 09:42 PM
DB8's Avatar
DB8
Default HELP: Tires Size, 19 x 9.5 +20 offset ? ? ?
Hey fellows,
any tire suggestions?
Front: 235/40/19
Rear: 275/35/19
Above correct?
Thanks in advance......
Old Jun 26, 2011 | 09:56 PM
AroundMyHorn's Avatar
AroundMyHorn
If I were you I would 275/35 on all four corners and add a spacer to the rear. Better yet, get rid of the rear wheel sizes and go with 10.5 +20
Old Jun 26, 2011 | 10:03 PM
DB8's Avatar
DB8
Thanks for the quick help.....
Anything needs to be done to the fender/suspension to fit the 275/35 in the front??
I am currently running 235/40 and 275/35 on a 8.5/9.5 setup
These new wheels that I just got does not offer the 10.5 or else I wouldnt give it a second thought
Thanks again
Old Jun 27, 2011 | 01:03 AM
MyV6IsFast3r's Avatar
MyV6IsFast3r
275/35 all around with a 10mm spacer in the rear sounds just about right to me.
Old Jun 27, 2011 | 01:22 AM
DB8's Avatar
DB8
Thanks again.....
but do I have to DO ANYTHING to fix the 275/35/19 inside the front fender ???
and will it drive funny with 275/35 on all 4 corners???
10mm - 15mm spacer will be added to the rear
Old Jun 27, 2011 | 03:21 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
275/35 on a 8.5" wheel? No thanks. 245/35 front 275/35 rear should suit you just fine with no fender modifications.
Old Jun 27, 2011 | 03:32 AM
For wheel-tire width see: http://www.tiresandco.ca/equivalency-tables-advice.html
Old Jun 27, 2011 | 08:18 AM
AroundMyHorn
The wheels are 9.5, not 8.5 FYI.
Old Jun 27, 2011 | 08:29 AM
AdvanZ33's Avatar
AdvanZ33
Thanks, I misread post #3.
Old Jun 27, 2011 | 08:14 PM
DB8's Avatar
DB8
I suppose I be safe with something like a
FRONT = 255/35/19
REAR = 275/35/19
Old Jun 27, 2011 | 08:28 PM
FRONT = 255/35/19
REAR = 275/35/19
275/35/19: Actual speed 100.0 MPH. Speedometer will read 100.39 MPH. This is perfect.
Old Jun 27, 2011 | 09:58 PM
DB8's Avatar
DB8
thanks davidv
But only only concern is actually fitting the 275/35/19 up front???
no mods needed (roll/pull)???
I am a newbie to the 350z scene, just something that doesnt sound right using the same width tires on all 4 corner. I kindly worry that the car will drive weird
Thanks again
Old Jun 27, 2011 | 10:45 PM
MyV6IsFast3r
NO..... You will not need to mod the front at all. That is why we have been saying this size. I used to run a 275 up front on a 9.5 +15 with 0 problem and i tracked if that eases your mind.
Old Jun 27, 2011 | 10:53 PM
MugenR's Avatar
MugenR
are we talking about stock height here? or 275 tires clear even with when lowered with 1 inch or a bit more?
Old Jun 27, 2011 | 10:57 PM
MyV6IsFast3r
Both
Old Jun 27, 2011 | 11:18 PM
terrasmak's Avatar
275/30-19 front
275/35-19 rear
255/35-19 front
275/35-19 rear
These are your two best choices.
Old Jun 28, 2011 | 01:06 AM
angelo350z's Avatar
angelo350z
I would personally do 265/35 front and 285/35 rear. Just keep in mind that even with identical sizes, different tire brands will give you a different look. Bridgestones usually have a narrower diameter than most. I currrently have 19x9.5 +22 with 255/35 RE-11s in the front and the tires look a bit stretched. I ran LMGT4s a while back and I had the typical 19x9.5 +30 with285/35 Hankooks which looked good, though the sidewalls did not look entirely square. I'm definite 285 Bridgestones would have looked better.
