oxidation on volks ! help !
Old Jul 12, 2011 | 01:17 PM
mikex228's Avatar
mikex228
Default oxidation on volks ! help !
I was out of town for a few days and when I came back I found a puddle of rust on just one wheel. I was able to wipe away the rust but now there is a hazy oxidation area left in the shape of the puddle. I've owned these wheels for two years and have never had any problems till now. Everytime it rains and water collects in that one exact area on just that one wheel it rusts over. I've used polishing compounds, wheel cleaner, etc all by hand but no luck. Any help would greatly be appreciated. Thanks !
Old Jul 12, 2011 | 01:42 PM
kno's Avatar
kno
that oxidation came from the brake discs. ive seen that form on my lip but never let the water dry to stain the lip, gl
Old Jul 12, 2011 | 01:51 PM
mikex228's Avatar
mikex228
hmm i guess that would explain it, i have a warped rear rotor im fixing tmrw in the rear...any info on how to remove this damage would be awesome
Old Jul 12, 2011 | 02:35 PM
lgear080's Avatar
lgear080
if it's in the clear you might be stuck? have you tried a buffing wheel and compound?
Old Jul 12, 2011 | 03:13 PM
mikex228's Avatar
mikex228
i hope its not the clear..cant imagine i thought the clear coat is very hard to damage...i havent used a buffer yet just because i dont have one...guess ill have to buy one
Old Jul 12, 2011 | 03:22 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
^clear coat is pretty easy to damage on volks with a polished lip.
Old Jul 12, 2011 | 03:52 PM
Blck350z's Avatar
Blck350z
There is a sticky in the wheel area.
What I was always told and it seems to work, treat the wheel exactly like you treat the paint on your car. I would start with car wash, move onto clay bar.... then cleaner wax if it is not gone then a nice wax to finish it off.
Everytime I wash my car I wash my wheels the same way...
Volk GT-S owner for 4 years
Don't let those winnings become a failing (egh... it sounded funnier in my head lol)
Old Jul 12, 2011 | 04:08 PM
FATPUBUS's Avatar
FATPUBUS
I had to end up wetsanding my lip on 1 wheel with a 800, 1000, 1200, 1500, and finally 2000 grit to get the same thing out. It's pretty tedious, but removed the rusty spot. Basically I took off the clear and just had to make sure it was polished and waxed every 2 weeks!
Old Jul 12, 2011 | 04:29 PM
lgear080's Avatar
lgear080
^ this is how i dealt with my meisters, however this requires a ton of work to
get started. in retrospect it should be done w the wheels fully dissassembled to
make the removal consistent.
Old Jul 12, 2011 | 08:00 PM
mikex228's Avatar
mikex228
ehhh deff dont want to entertain the idea of sanding...probably hit it with a buffer first if not ill just have to suck it up...
if anyone knows of some kind of compound that will help remove this feel free to share
Old Jul 13, 2011 | 07:15 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
3M system. First use the cutting compound, then the machine polish, and finish it off wih a bit of wax. I personally use meguiars. That should sort it out.
Old Jul 13, 2011 | 07:01 PM
Volks wheels cannot be harmed by man or nature. These must be replicas.
Stevo Z
Oct 3, 2015 09:14 PM
