Low PSI does not go away!
Old Dec 17, 2003 | 06:36 AM
BIGGY's Avatar
BIGGY
Default Low PSI does not go away!
From my understanding...when you break above 28 or 29 PSI, shouldn't the warning go away? Mine stays right there. Is this I just got the car like 4 days ago...don't tell me somethings wrong with the sensors and I have to take it in! Is there a certain PSI that the tires have to get above for it to go away? And from my reading, you can't clear the warning away, it's supposed to turn off? BTW, I'm driving a 2004 model if there's any differences.
Old Dec 17, 2003 | 07:29 AM
FLY BY Z's Avatar
FLY BY Z
Try putting air in your tires.
Old Dec 17, 2003 | 07:56 AM
matt g.'s Avatar
matt g.
try resetting the ecu. my car did this and it took about two weeks of driving before the warning light went off. ( did not try the battery thing tho. )
Old Dec 17, 2003 | 08:34 AM
BIGGY's Avatar
BIGGY
Great...how do you reset the ECU? If I simply select the tire presure display (front or rear), then hold the bottom right button (the -)...should that reset it? Doesn't seem to now, or do I have to be stopped?
I also noticed that the temp does not change between F and C...it's always on F. Any info there?
Old Dec 17, 2003 | 10:00 AM
FLY BY Z's Avatar
FLY BY Z
Seriously, put 36 psi in your tires and drive around. It will turn off.
Old Dec 17, 2003 | 10:05 AM
Blue350zCali's Avatar
Blue350zCali
FLY BY Z is correct put air in the tires, also dont trust the PSI guage at the gas stations. This happened to both the Z and the Murano. Go buy a tire pressure guage and make sure all your tires are at around 35psi cold.
Old Dec 17, 2003 | 12:10 PM
ares's Avatar
ares
Veteran
32 is the magic number; its wieird tho; sometimes itll set off at 28; but it wont beep unless its UNDER 28. and sometimes itll go off at 32; but once I had 3 tires at 39 and 1 at 31 and it went off. but its generally 28-32 is your range to get it on and off; with what seems to be some flexability.
Old Dec 17, 2003 | 01:01 PM
D'oh's Avatar
D'oh
The stock tires should be 35 COLD, so you definitely should be adding air.
No reason to reset the ECU.
-D'oh!
Old Dec 18, 2003 | 05:45 AM
BIGGY's Avatar
BIGGY
yup, that worked...thanks everyone
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
