Tire Setup Questions
Old Nov 8, 2011 | 06:26 AM
Zhinobi's Avatar
Zhinobi
Smile Tire Setup Questions
245/40/18 30off front 275/35/18 15 off rear without issue when lowing?
Running 18x8 and 18x9.5
P.s my friend told me I should do 15mm spacer in the front.
Thank you for your help in advance
Old Nov 8, 2011 | 07:09 AM
Zhinobi's Avatar
Zhinobi
Anyone please?
Old Nov 8, 2011 | 07:32 AM
NZMOWND's Avatar
NZMOWND
yes u will be fine
Old Nov 8, 2011 | 07:38 AM
BoomerZ33's Avatar
BoomerZ33
according to those specs, 20mm front and 15mm rear is what i would do. if you lower the car a lot then you will need a fender roll.
Old Nov 8, 2011 | 07:43 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
As long as those offsets are positive, you're more than okay.
Old Nov 8, 2011 | 07:49 AM
VO...'s Avatar
VO...
Administrator
moved...
Old Nov 8, 2011 | 08:03 AM
Waiz's Avatar
Waiz
Read this thread:
https://my350z.com/forum/2003-2009-n...questions.html
Your question would have been answered here:
https://my350z.com/forum/2487452-post8.html
Q: What wheel sizes and offsets do I need?
A: Generally speaking, there are a LOT of different combinations that people are running on their Z or G.
Let's get the basics out of the way first: You need a lug pattern of 5x114.3, width between 8 and 11 inches, and diameter of 17", 18", 19", or 20".
Here are some of the more popular wheel and tire sizes (for good reason) that people put on their Z's. There is no "RIGHT" answer but there is a limit to how big or small you can go.
18" combination:
Front 18" x 8.5" , Offset +15 to +25, Tires 245/40/18
Rear 18" x 9.5" , Offset +15 to +25, Tires 275/40/18
(lower offset such as +10 in rear is possible but may require rolling)
Front 18" x 9.5" , Offset +25 to +30, Tires 255/40/18
Rear 18" x 10.5" , Offset +28 to +35, Tires 285/40/18 or 295/35/18
(lower offset such as +23 in the rear is possible but may require rolling)
19" combination:
Front 19" x 8.5" , Offset +15 to +25, Tires 245/35/19
Rear 19" x 9.5" , Offset +15 to +25, Tires 275/35/19
Front 19" x 9.5" , Offset +25 to +30, Tires 255/35/19 or 265/35/19
Rear 19" x 10.5" , Offset +23 to +32, Tires 285/35/19 or 295/35/19
(lower offset such as +23 or wider tires in the rear is possible but may require rolling)
From this, you get the idea of what is required to go with smaller wheels like 17's, (typically lighter, faster acceleration), or bigger wheels like 20's (bigger, heavier, usually makes you feel slower).
Get to know how to use the following tools and you will be able to figure out for yourself the correct offsets and tire sizes you need:
Tire size calculator (click)
Wheel Offset Calculator
Certain combinations of LOW OFFSET and/or WIDE WHEELS will require what is known as "fender rolling" or "fender cutting".
If you are not familiar with the term "fender rolling", here is a quick but useful lesson you can learn in a couple of minutes: Go outside to wherever your Z is parked. Run your fingers along the inside edge of a REAR fender just above your tires. You will feel a sharp edge and a flap of metal sticking inward towards the car. Now, go up to the FRONT fender, and feel the inside of the fender again. You should notice that the flap of metal has been "rolled" upwards on the front fenders. This is exactly what fender rolling is all about. The rear fenders will need to be rolled to make room for wide wheels or low offsets, or else your tires may rub on the metal when you take hard corners or hit bumps. Any experienced wheel/tire shop should know how to roll a fender. If you go to a shop that does not seem like they know what they're doing, get out of there.
<!-- google_ad_section_end -->
Old Nov 8, 2011 | 08:32 AM
scotts300's Avatar
scotts300
Front tire is taller than the rear tire; I don't like it.
Front wheel will be set in like stock. This is fine, but you may not like the look after spending $ on the wheels. 15mm front spacer would be nice. Rear should be good, no need for a roll with most 275 tires on an 18x9.5 +15 wheel.
Old Nov 8, 2011 | 08:36 AM
terrasmak's Avatar
18" combination:
Also pay attention to the 275/40 part if you want the ABS/VDC/TCS computer to be happy.
Old Nov 8, 2011 | 09:06 AM
Zhinobi's Avatar
Zhinobi
Thankyou for all your help guys. I decided to go 18x9.5 15off all around with 245/40/18 front and 275/35/18 rear
But what the best spacer size to go with? I'm prepare to fender roll if need to. I want that aggressive look.
Old Nov 8, 2011 | 10:43 AM
scotts300's Avatar
scotts300
I hope your car is a base model, or you will be turning off VDC all the time, especially in the wet when you want it most. I'd stop the shipment on the 245/40s and get 275/40s for the rear while using the 275/35s for the front. Hurry.
Old Nov 8, 2011 | 12:12 PM
Agree. Is this your intension?
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
